Question about Kitchen Appliances - Others
Furnace is turning on but cutting off then fan is is turning on then unit cuts off. Furnance was originally installed at below sea level and now is installed at above 4000 feet above sea level. Panel states to adjust to above sea level but does not tell how to adjust. Furnace is a Coleman Evcon model # dgat056bde serial #980854038
  • 63 Answers
Hi my name is mark, i went to coleman website. please go to website and check safty notice. http://www.colemanac.com/dealers/index.asp i hope this helps.
Posted on Mar 14, 2009
After preheat the fan cuts in for 10 sec then cuts out, cuts in for 15 sec, then cuts out. this continues to longer interviles. I have replaced computer box twice and have spent hundreds and problem
Try Googling the problem. Who have you paid so far, someone from the gas company, or a private technician? Was the technician from an Intertherm dealer? I would think a dealer would have qualified techs.
Nov 26, 2013 | Intertherm 56000 Btu Gas Furnace
Hi i have installed a lowrance m52 s/gps in my boat i have turned it on while boat still on trailer and the unit is reading 5.6 ft deep, is this what it should say?
GPS uses satellites to determine position and altitude. Depending on where you are, above or below sea level, it may say you are flying in the air or a few hundred feet below the water. YOU have to determine what your mean altitude is by knowing what the local altitude is above or below sea level. If you were in Denver, Colorado, it would tell you that the boat was about 5,341 feet up in the air. In Death valley you would be below the water because it is below sea level, -272 feet.
Aug 25, 2012 | Lowrance Boating
I have a Haier air conditioner model HWR10XC6. It's been in storage since last fall, and I put it in our window this morning. I plugged it in, and the light on the panel came on for a split second,...
First check if the fan is running. If the fan is notrunning is the compressor not running also, if neither is running the possiblereasons are 1, no power to outside unit, 2.bad contactor on outside unit, isthis buzzing if it is this indicates no power, 3 bad capacitor, do bothcompressor and fan humm then quit humming and hum some more, 4 high pressure switchhas shut unit down because fan wasn't running if compressor was running but notfan, if your unit has this there will be a manual reset button where the lines come out ofunit. If compressor was running and fan was not, 1 bad fan or 2 bad capacitor. Please check these followings: 1. Thermostat checks i) Is thesystem selector switch in the "Cool" position?
ii) Is the temperature set at least 3 degrees below current room temperature?
iii) If your thermostat is electronic, are the batteries charged?
iv) Some forced-air furnaces have a switch on the thermostat that allows you toturn the fan on independently of the furnace or air conditioner. This switchwill be marked "ON" and "AUTO". Does your thermostat havesuch a switch?
v) If the answer to the above is Yes, listen for the furnace fan coming on. Ifyou cannot hear the fan, go to one of the supply registers and see if you canfeel any air coming up. Is the furnace fan operating?
If everything seemsfine with the thermostat, the next step is to make sure there is power going tothe furnace.
2. Electrical checks
(A) Items to check at the furnace
i) Your systemmay be equipped with an emergency shut-off switch for the furnace. If so, makesure it is turned ON. In most homes, the emergency shut-off switch looks justlike a regular light switch and will be located close to the furnace. (Tracethe wire from the switch to the furnace to make sure you have the right switch.)It is quite common for this switch to be turned off accidentally. If the switchis ON, but the fan still doesn't operate, proceed to the Items to check at theelectrical panel.
ii) Some heating systems also have emergency cut-out switches that are activatedwhen a door or service panel is removed. Often the furnace door is not replacedproperly after a filter cleaning and the cut-out switch will prevent thefurnace from coming on. Check to make sure all access doors are properlysecured and fitted. (B) Items tocheck at the electrical panel i) Thebreakers for the air conditioner and the furnace should be in the"ON" position. If a breaker has been tripped, it will be in aposition between ON and OFF. To reset, turn the breaker all the way off and thenback on. If you have fuses instead, make sure the fuse hasn't blown. If it has,replace it with the same-d fuse. If you havedetermined that there is power to the furnace but you are still not getting anyheat, select your heating fuel type from the list below and continue with thechecks. If you have discovered that the furnace is not getting any power, callyour service contractor. (C) Items tocheck at the air conditioner i) Somecentral air conditioners are installed with a switch, or electrical disconnect,mounted outside to turn off the main power to the unit. Whether or not you havesuch a switch will depend on the electrical code in your area. If you have adisconnect switch, check to make sure it is in the ON position.
ii) Is the fan running on the unit outside? (If the fan is running, you havepower to the unit.)
iii) Some air conditioners will make a little buzzing sound, even when they arenot running. Have you ever noticed this before? Can you hear it now? Summary: Ifyou have determined that there is power to both the furnace and air conditionerbut you are still not getting any cool air, continue with the checks in thisguide. If either the furnace or air conditioner does not have power, call yourservice contractor. (D) Icechecks i) Is thereice building up on the pipes connecting the furnace to the air conditioningunit outside?
ii)Touch the plenum (this is the sheet metal box that comes off of the furnace;the evaporator coil is inside). Does it feel very cold? If it does, theevaporator coil may be frozen and you'll need to call for service Hope this will help you. Good Luck.
Jul 15, 2011 | Haier hwr10xc6 Air Conditioner
I have a Johnson aire ease ultra 90 gas furnance. I also have a outdoor wood furnance that has its own thermostat. On the original thermostat I turn the blower in the on position. I then set the outdoor...
I would first eliminate one furnace from the equation, the exterior wood furnace... turn its tstat down. Will the gas furnace then operate normally? Can you run the blower manually, as in summer mode? Make sure your filters are clean also... that can sometimes overload the blower.
Apr 12, 2017 | Heating & Cooling
Compressor for air will not cycle on.
Check and see if you have a common wire on the thermostat. If you do not, then you will need to replace batteries if applicable.
If you do have a common wire, then batteries are not necessary for thermostat operation.
Even though the thermostat wires are secured properly and the thermostat worked fine in the heat mode, it doesn't mean it will work for the AC mode.
If you want to check the thermostat in an easy manner, you will need to jump out the Red and Yellow terminals at the thermostat. Be sure to turn off power first to the furnace. After jumping out, restore power to furnace. If the unit comes on, then your thermostat is bad. If the unit fails to come on, you have another issue. You can repeat this process at the outdoor unit with the low voltage lines if you feel capable. If unit comes on, your problem lies between thermostat and outdoor unit. If your unit fails to start, your problem lies within the outdoor unit.
Be sure to check any drain pans, float switches, or cut-out safeties installed that may cause this. Many contractors will wire in drain safeties to the outdoor unit to shut down the compressor in the event a drain line has clogged and backed up into the emergency pan. Of a condensate pump has failed.
If you do not feel you are capable of this, you may need to contact a local professional to come diagnose the situation. But those are a few simple tasks that you can complete yourself to narrow down a problem.
May 26, 2010 | Heating & Cooling
Indoor fan motor continue to run even if the thermostat is in auto position with the cool and heat switch in the off position. The furnance don't have a fan on and off switch in the furnance like most....
Try this, disconnect the fanwire (green) on the furnace, if it shuts off then the hot wire from the thermostat is touching the green wire or bad thermostat. Thank-you-very-much!
Aug 26, 2008 | Intertherm Heating & Cooling
Ruud heat pump high pressure cut off problem
That's going to be in your installer configuration. Check and make sure the G terminal has a wire connected to it at the tstat , and that connection it tight. In the configuration menu, make sure it is set for a heat pump, elected heat. It seems to me that the tstat doesn't know its connected to a heat pump. Should be able to locate aodel # for tstat on the back of it. And ask Mr. Google for a manual, if you don't have 1. Hope this helps!
Mar 18, 2017 | Heating & Cooling
Fan continues to run after desired heat is established , I blew out the line at pilot and the unit is taking 10 to 15 mins for fan to cut off
Looks like your fan limit switch may be bad. It fits into the warm air side of the furnace. It tells the fan to come one and off when the heat is blowing over the limit switch. Now if that limit is defective it also will affect the lighting of your heater being it electronic ig-niter or just common thermocouple type controlled pilot light. Now above your post I think the wong information was given about your gas heater, so giving you the exact information will be difficult. Now from hearing you explanation of the problems, I hope my information was a help to you, Thanks Sea Breeze
Oct 26, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Kitchen Appliances - Others Logo
253 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
