Question about HP LaserJet 1300 Printer
I have hp laserjet 1300 printer.
I am having trouble because the print that shows up when I print things is way too small to read. I tried going into the control panel, then go to printer/faxes menu. Then look and try to switch the font size. But it does not work. I need a way to make so the print is bigger and what I tried to do which was explained with someone else having the same problem did not work. Can someone please help me with this issue.
Thanks
Steve
  • 34 Answers
Only thing you can be sure of ---this is not a printer problem. It is a computer issue.
Posted on Mar 13, 2009
My HP laserjet 1300 has something blocking the printing process... it spools/pending for a long time then an error msg comes up. Its like a document is caught somewhere in the spooling process but not...
The last time I had a problem like this with an HP laserjet the problem turned out to be the need for increased memory in the printer and replacing a faulty memory module. Check your memory modules in that laserjet and make sure you aren't overloading the printers ability to process the information.
Sep 22, 2011 | HP LaserJet 1300 Printer
I now have my Laserjet 1300 paired with a Windows 7 system. For some reason I cannot print more than one copy at a time from any of my applications. If I select one than one copy for printing, the system...
Hi Jcerny1!
This is what you should do:
Press the Start button and go to "Printers", and then right click on your printer (should appear as HP LaserJet 1300), and "Properties". Go to "Device Settings" and find Job Storage and Mopier Mode (they are at the bottom of the window). They're probably set to Enabled , so you need to choose Disabled for both (Job Storage and Mopier Mode). Click Apply and OK. Try printing multiple copies now. If it doesn't work, trying rebooting the computer and then trying to print again. It should work now.
Dec 15, 2010 | HP LaserJet 1300 Printer
How do I connect 2 computers to one HP LaserJet 1300 printer?
on your desktop go to printers and share your printer. then from your laptop go to printers click add new printer. then choose a network printer and click find or search to find the printer conencted on your pc. the pc has to be turned on in order to print
Jan 21, 2010 | HP LaserJet 1300 Printer
HP Laserjet 1300 is printing many pages on one sheet
Sir,
Try to re-adjust the cartridge or reinstall the catridge it will solved
Thanks Good Luck
Jul 21, 2009 | HP LaserJet 1300 Printer
Ghost prints on HP-1300
The cartridge could be bad. Just saw same issue earlier on another HP doing the same. Inspected the fuser and it had a place it the middle that the teflon coating was worn off. Try cartridge first, then look at the fuser with flashlight. Do not stick anything into the fuser. Make sure machine is powered down,unplugged and allow it to cool down before attempting to touch area. It will burn you, they get hot!
Feb 13, 2009 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer - Won't feed paper
firistly try to find out the printer is ready or not then find out when we powearing on the printer then it is warming up or not if it is warning up and not come to ready position then open front cover pull the toner cartage and send back it propely
then give print if the problem is not solved then ckeck the printer cables and drivers
Jun 28, 2008 | HP LaserJet 1300 Printer
Hp laserjet 1300 prints extra blank page
did you try the hp laserjetIII driver
Apr 22, 2008 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
60 people viewed this question
Ben Johnson
