Question about Sony PCV-RS620G PC Desktop
Gateway Model #0019401806 - Power Button in 'off' position
The tower of my Gateway Model #0019401806 has a power button on the front side of the case and is stuck in the 'off' position. The plastic button piece needs to be replaced - but I don't know with what - also I can't seem to gain access to the back of this front panel case. Any ideas how I can get to this to fix it and maybe replace it?
Thanks.
  • 5 more comments
  • rsljll Mar 06, 2009
    I was able to remove the back of the case but there seems to be no access to get to the tabs on the front side of this tower. Any suggestions? What kind of switch can I replace it with?
    There is no alignment problem - what are referring to?
    I have the back case completely off and there are no visible 'tabs' that I can even GET to - even if I took all the drives out from the front it still doesn't get to the power swtich. Your answer was not clear. or helpful.
    The tower of my Gateway Model #0019401806 has a power button on the front side of the case that is stuck in the 'off' position or down position. The plastic button piece is depressed into the front panel and I can't see access to it by going through the back with the case off. Any ideas how I can gain better access to this front panel and get to the 'power button'?
    Please read my last post....by taking off the back of the case - it doesn't allow you access to the FRONT of the panel where this button is located. I can't see any tabs to depress to pop off this front panel piece - I'm stuck.
  • rsljll Mar 10, 2009
    I am trying to get an answer to taking the front panel off of my Gateway desktop Model 0019401806 to replace the power button that has broken off and/or fallen off. I have tried all the suggestions and nobody's gotten it right yet.....any ideas?
    This does not answer HOW TO GET TO THE POWER BUTTON. Nobody can tell me how to get the front panel off - removing screws doesn't show anything, both side panels are removed and there is nothing I can see that holds the front panel in place.
  • rsljll Mar 12, 2009
    I don't believe the solutions offered match the particular tower I specified but thanks just the same.
    The way I'll figure it out is for someone to recognize the model # I gave - but again, thanks for your overwhelming, positive attitude.
    Scholar:
  • 164 Answers
Hello There
This is reasonably straight forward problem to solve. The front cover on your unit comes off. These are either stuck on with clips so it just needs to be pulled out, there might be some hook clips which you might have to lift and then pull out the front facia. with regards to the button if you are lucky it might be something that might release itself after you have removed the front cover but if it is damaged than you can replace it with any simple On/Off (I/O) switch. You should be able to get one from any electrical component store.
Hope this helps.
PCGuy30
Posted on Mar 10, 2009
  • Sony Master
  • 19,396 Answers
The power button alone is not sold, and not all cablinets mount the same kind of power switch.
To fix it properly you need to replace the computer case that is not an expensive part: Amazon.com: Computer Cases: Mid-Tower, Server, Full-Tower, Desktop .
To find a temporary runaround fix you can remove a switch with the two wires and the small connector from an old coumputer, hook it to the motherboard, and instead of mounting it on the cabinet front, as they usually do not match, leave the button out, with the wires popping up from underneath the case on one side.
Posted on Mar 09, 2009
  • 408 Answers
Ok, if you have the left side of the computer case off, there should be 3 tabs, I believe they are grey.  They are in the top, middle and bottom.  You have to depress these and "swing" the front panel away from the computer, like you would as opening a door to your house.
Posted on Mar 06, 2009
  • 3 more comments
  • Shadow1989 Mar 06, 2009
    [IMGhttp://i11.photobucket.com/albums/a194/a...[/IMG]
    Try that.
    There we go...couldn't figure out how to insert a pic.  lol
  • Shadow1989 Mar 11, 2009
    My comment shows exactly how to take the front panel off.  The power button can only be removed after you take the plastic front panel off.  You take those three tabs and pull them back and push the tab through the inserts.  That will remove the front panel, after which you can access the power button.
    If you are still having issues, post your specific model number.  This can be found on the front of your computer. It may start with a letter or number, such as G166 or N1400
    Master:
  • 404 Answers
It is hard to find a replacement power button for cases like these, I suggest you take the button out completly and find the missing parts inside that broke and use a glue to glue it back and then put the button where it was.
the usual thing is the spring gets out so find the spring it's just once you take the button out you'll figure out the rest yourself. this wont hurt you pc at all.
if you can't find anything to do with it. then you can buy an external button from ebay which connects to the motherboard. it wont be as nice but it does the job
  • lotfi bouakaz
    lotfi bouakaz Mar 10, 2009
    shadow just showed you how to do it. if you don't know how to figure out removing the front panel how are you going to think of solving the power button problem?. I strongly recommend a repair shop private and local.
    Brigadier General:
  • 8,619 Answers
Hi!
Remove the two screws from the back right side of your tower, remove the side panel. Now you will be able to see the on/off button. Try to see some thing is it obstructing it else remove and replace it.
  • 154 Answers
There must be some alignment problem in the button.
  • Sony Master
  • 13,433 Answers
Can you please double check that model number? tell me anything that reads on the computer case.
Thanks
  • Ekse Mar 06, 2009
    I would know alot more if you could tell me the model of your computer. Thanks a lot.
  • Ekse Mar 06, 2009
    It appears you have posted us a serial number instead of a Model.
    This seems to be a gateway select 750.
    Documentation is limited on this model.
    Open up the computer case, you will need to get the front panel open. Unscrew all screws that seem to be connected to the front panel. Also if in this model you can remove the other side of the case also, then please do that, also unscrew all screws on that side that seem to be connected to the front panel.
    Eventually you should be able to get the front panel out of the computer. and simply replace the button or fix it if possible.
    I will have to look into this more to see what kind of a computer you got there.
Lost power button got turn off
try this; carefully detach (pull off) the front panel of the base tower unit.. and behind the plastic front that you just took off there's a little button that you can push to power off and on. The power button just goes through the plastic cover and pushes the button.
Jan 04, 2016 | Gateway Computers & Internet
Power button switch
Send a request to the following email address. Mention the exact model number like you did in your question and request a replacement front panel on/off switch. rma@raidmax.com
Nov 19, 2013 | RaidMax AURA ATX-927WB Black SECC Steel...
Replace power button gateway sx 2311
Computer unplugged from power, FOLLOW Anti-Static Precautions.
1) Remove the Side Panel.
Viewing the computer from the Front; the Right Side Panel removes. Remove screw, pull Side Panel to the rear of the computer.
http://www.newegg.com/Product/Product.aspx?Item=N82E16883113140
Click on the large main photo.
There are 9 smaller views shown. 3 across, and 3 rows.
Bottom row, click on the photo in the Middle.
Shows Rear view of computer.
Along the back edge of the Side Panel, is a finger pull handle formed out of the Side Panel. There also looks to be two screws. One above the pull handle, one down towards the bottom.
2) Remove the Front Bezel.
Click on the Middle row/middle photo.
Also look at Middle row, 3rd photo. (Photo all the way to right)
There are 3 Black tab locks, formed out of the plastic of the Front Bezel. One towards the Top, one in the Middle, and one towards the Bottom.
If memory serves these tabs are gently pulled to the outside, to release the Front Bezel. Ease the Top tab out a little, and Middle tab.
Start easing the Front Bezel away from the metal framework, of the computer case, a little. Then release the Bottom tab.
Front Bezel should swing, and then come off.
Not your Gateway model of computer case, but this Gateway model shows the plastic Tabs to release,
http://support.gateway.com/s/CASES/3501975/3501975faq6.shtml
The Power On Button is an assembly. The plastic housing of the Power On Button assembly, has a Power On switch inside.
I gently heat the plastic with a hair dryer, moving the hair dryer back, and forth at it.
Once the tabs of the plastic, of the Power On Button assembly, is softened; then I remove the Power On switch.
I have found this ATX power on switch, fits a LOT of desktop computers,
http://www.directron.com/atxswitch.html
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 19, 2012 | Computers & Internet
On off button not working
We need to follow some Troubleshooting steps
power off the tower
disconnect the power cable
1.open the side panal of the tower
2.then open the front panal of the tower
3.the please toggle the power button from inside the tower
4.then put back the front and the side panal
connect back the power cable
restart the pc using the power button
it will start working
Jan 13, 2011 | HP Compaq Presario SR1830NX PC Desktop
I need to replace the power button on a Gateway E4000 mid size to
I think you will find this site useful in assisting you with removing the cover. I think you can scan directly to pg 107 for the "mid-tower" http://nzr.mvnu.edu/facilities/items/gatewaye4000manual.pdf
Mar 26, 2009 | Computers & Internet
Gateway Model 0019401806 Tower - Power button fell into case
there are tabs inside the case that you depress to pull the front cover off. once pulled off you should be able to replace the switch.
hope this helped
please rate well.
Mar 06, 2009 | Sony PCV-RS620G PC Desktop
I have a V2Premier computer (Tower) the power button fell
Sure. You can even replace it with any momentary switch (Normally Off position switch) from radio shack or like places.
Jan 24, 2009 | Sony PCV-RS620G PC Desktop
I have a Gateway 300x Micro-Tower case circa 2002 and I can not open the case, without breaking it. I'm trying to install a new audio card and can't get at the 300x innards. Help!
Most of these towers are vertical style, therefore the big button is just to the left of the Gateway symbol. Push it in and pull the left panel away from the case.
Jan 11, 2009 | Computers & Internet
Open Gateway ES2 300X case
Apr 30, 2008 | Computers & Internet
Sony PCV-RS620G PC Desktop Logo
122 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
