Air Tools & Compressors Logo
Posted on Mar 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does anyone know who manufacture MAC air impacts, in paticluar the AW434. My impact has little rpms.
JohnjacobJinglehimmersch
Level 2:
Champion:
  • Expert 234 Answers
  • Posted on Feb 29, 2012
Expert
Level 2:
Champion:
Answers
234
Questions
0
Helped
47744
Points
466
The 434 is made by Ingersoll Rand. You can still buy a vane kit for that model for about $60, I think it comes with bearings. Don't forget to use an inline oiler as well as to grease the gun occasionally to prolong its life.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2756
Points
Mac does not design thier own my mac AW480O is a aircat and so is the new one i bought today and along with my 3/8 and my 3/8 air ratchet and the other stuff is IR ask your ask your mac guy he should know and to answere the ? you need to rebuild it or oil it
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4318
Points
It is probably gummed up from moisture. You need a good air dryer for your air supply. These models are susceptible to moisture. You can take it apart and clean it yourself without incurring extra expense.
Jim London
Level 2:
  • Expert 257 Answers
  • Posted on Mar 06, 2009
Jim London
Expert
Level 2:
Answers
257
Questions
0
Helped
273198
Points
839
Hi, Mac tools has been around forever, Mac is the manufacturer. Look up mactools.com. This should Fixya!
Need rotor,3051-007for MAC/aircat 1/2in.impact
Here is a link for the parts list and a retailer that sell this part.
Parts list: AIRCAT Pneumatic Tools Schematics
Retailer: Power Tool Repair Search Results for 305h 007n
Hope this helps!
My 3/4" ingersoll rand impact has little power how do i fix?
A very common problem with most impacts is the incorrect size of the air fittings and air hoses, follow the MFG'S suggestion located in the owner's manual. Most 3/4" impacts need a 1/2" i.d. hose with 1/2" series air couplers. All I.R. impacts have a screen on the inlet bushing that can become clogged with debris and will cause a low power condition, make sure it is clean. If the problem persists disassembly and inspection of the tool will be necessary. Most common problems are damaged / worn motor vanes, bearings, gaskets, seals, scarred endplates. Special note for IR261 the endplates along the edge have small plugs that can deteriorate cause an internal air leak causing low performance.
Follow this link to find the parts list for you model:
http://manualarchive.ingersollrandproducts.com/
Hi, I was wondering if anyone could help. I have a little 1/2 impact that has seemed to lost it hitting. I was wondering if it needs to be greased? So is the a grease I should use?
Hello.
Put two drops of light machine oil or pneumatic oil into the air inlet connection and then hook up the air line. Run the impact at full throttle for 20 seconds. You should oil it daily, two drops. Too much oil is as bad as too little, as too much oil can close off the ports and cause the gun's operation to fall off.
Best regards, --W/D--
Mar 06, 2011 • Garden
I have tried to rebuild my MAC AW480Q impact wrench, but it still only has about half the speed and power that it should. Does anyone know where I can get instructions on the proceedure of how to rebuild...
One thing to really look at on these is the condition of the cam, hammer pins, and anvil where the pins contact it. It makes all the difference in the torque if these are worn. Also, check the rotor bearings, condition of the cylinder and seals as well. The rotor vanes are most important on their lenght from one end of the cylinder to the other. A loose fit there leaks a lot of air and looses power
My 1/2" pneumatic impact gun runs at full rpms but you can stop it with your hand.......what do i need to check
Is this an expensive gun?If not this might be normal.If not the hammer in the gun is what makes it tough,So the hammer is worn out,and may be the cylinder it travels in.Try a thicker oil to see if it helps,or henders the problem.If it is the hammer,you will have to get it fix by a tool repair shop,or find on line,and order and install part yourself.
2helpful
Where can I buy parts for a CP722 air wrench
from any Snap-on tool dealer or MAC tool dealer, u can also order them direct from manufacturer web site, have this gun myself.
Can't find a rebuild kit for POWERMATE air impact wrenck model o024-0099sp.
well pretty much IR (ingersoll rand) makes almost every impact out there. So you can try to navigate their web site, call sears or if you have a Snap On dealer, or matco, or cornwell, or Mac tools. Just call or check out the snap on website see what the dealer for your area is. Tell them what you got and they should be able to find you a kit. They are in the tool business and keeping mechanics wrench'n .
2answers
Air Wrench Question
An impact wrench works in the manner suggested by the name of the tool: through the principle of impact. In order to understand how an electrical or air-powered impact wrench works, it helps to know first how a manually powered impact wrench operates. A manually powered impact wrench looks like a fat screwdriver; on the end where the screwdriver blade normally goes, you can snap on screwdriver bits or sockets.
2helpful
Wrench Troubleshooting
In line oiler Lubrication is critical to extending the life of your valuable air impact wrench and increase productivity. An air tool that has not been properly lubricated will result in low power output. The usual culprit is a dry motor starving for some oil. Your impact wrench is an expensive investment and you must take the time to properly lubricate it. The easiest and quickest way to make surein line oiler it is constantly lubricated is to install an in line oil lubricator. One of these will insure your air tools are receiving oil every time they are used. In line lubricators attach right into the air hose and you fill them with the correct lubricating oil. (see your manufacturer's specs.). You should also do routine external lubrication through the hammer case grease fitting. A well lubricated air impact wrench will deliver more torque, last longer, run quieter and increase productivity. Don't forget to add an in line oiler to your next impact wrench or air tool. It will pay for itself several times over.
Top Air Tools & Compressors Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
