Question about Toshiba 32AF43 32" TV
3yr old lcd television,picture starts off all over green on startup,reverts to normal picture after about 1 hr.sableman2003. television is a crown make, also strong black images are burned to screen in a green outline,have tried moving speakers etc that are near, any suggestions,thanks.
  • 3 Answers
PLEASE READ ALL OF THE FOLLOWING BEFORE PROCEEDING. If you feel confident,and ONLY so.Open the back, keep going until you are able to remove the small cable that connects to the top of the screen. It will be flat and approximately 2" wide, there will be one or more ribbon cables that go directly to the LCD display, but ignore these. Some manufacturers glue the flat connector in place, if this is the case with your model, use a hairdryer or hot air gun to soften and remove the glue, it is CRITICAL that you take care when doing so, as the connectors are very fragile on purpose. Then clean the contacts on the connector you can now remove with isopropanol or other fast drying alchohol with a toothbrush (not used), and reconnect it. You may wish to re-glue or using Electricians tape, secure it back in place. Many of these connectors are clipped in and have a latch that will need to either lift, or slide away from the PCB before you can gently remove the connector. Once you have cleaned the brass or gold contacts, very carefully replace and reassemble your TV.
Posted on Mar 06, 2009
Hi, I have a 3yr old lexsor 27" lcd suddenly the
maybe the lcd screen is the defect already, lcd tv often use daily has a shorter life span compare to crt tv's. also there's possibility the inverter power supply of lcd screen has defect, or the connector is loosen
Feb 06, 2011 | Televison & Video
My 32LD30UA LCD TV is 16 months old, when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.Help?
My HITACH 32LD30UA LCD TV when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.
Dec 12, 2010 | Hitachi 32LD8700 32 in. LCD Television
My LG flatscreen image emits an intermittent green tint and then reverts back to normal colors.
Sep 09, 2010 | LG 42LC2D 42 in. LCD HDTV
Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
Sep 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Screen went black
Check the power supply for 12 volts dc, it must provide at minimum 3 amps of power to trigger the on circuit. If not, replace the adapter... if you need one, please contact me.
Jan 12, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
All colour change on bush 37" tv
A wire in the set got too hot and broke away, had to pay £140 to get it fixed, was told it's quite comman in alot of lcd tv's, as in all makes... I t should have been for a lcd bush 37 inch tv,,,not that it makes any difference it applies to all flat lcd screens, I just posted in the wrong part to begin with.. Sorry.
Mar 27, 2008 | Acer AL2416WD 24 in. LCD Television
Vertical green lines
Call where you bought the TV. This is not normal for an LCD TV. They should exchange it only being a week old.
Jan 20, 2008 | Televison & Video
Color problem
my guess would be a cold solder joint on the av board. when picture looks good go to connectors and wiggle them if the set acts up you have your answer.
Jun 08, 2006 | Mitsubishi LT-3020 30 in. HD-Ready LCD...
Toshiba 32AF43 32" TV Logo
50 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
