Question about Dell 1600n All-In-One Laser Printer
Error on all in one laser printer dell scanner error
On my dell all in one laser printer the screen says to unlock the scanner and press cancel, but the scanner is not locked and we never use the scanner only the fax. please help. thanks
  • Anonymous Apr 21, 2009
    ON THE SCREEN SAY UNLOCK THE SCANNER AND PRESS CANCEL
Take it back to the company where you purchased it at!
Posted on Mar 06, 2009
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
How do I unlock the scanner on a dell laser MFP 1815 dn printer. I can't fax or copy anything. It says the scanner is locked.
There's a little blue toggle switch where the copies/scans come out from.
Pull the blue switch toward you, turn off the printer, wait a few seconds, and turn the printer back on.
Aug 27, 2010 | Dell Printers:Dell MFP Laser Printer...
ERROR 016-720 FOR DELL
The problem correspondent to this error code is: "Error relating to PCL emulation problems occurs."
The solution is: · Press the "Return" buttonto clear the message, cancel the current print job, and conduct the next print job, if any. Press Cancel to cancel the print job.
Mar 30, 2010 | Dell 3100cn Laser Printer
Can't unlock scanner
reach up under display on left and pull the blue lever forward.then push the cancel button. if that does not do it then turn off and back on. if still no go then your scanner itself is off track and needs to be but back on.
Oct 12, 2009 | Dell 1600n All-In-One Laser Printer
Printer problem - HP Photosmart 8150
If the printer cannot print or move any paper, follow these steps to display the Event Log. Otherwise, print the Event Log.
1. Press Menu until INFORMATION MENU appears.
2. Press Item until SHOW EVENT LOG appears. Press Select to show the Event Log.
3. Press - Value + to scroll through the Event Log.
4. Write down the error messages.
If you see a 52.X error then this indicates the following:
0 Laser/Scanner Error
1 Laser/Scanner Startup Error
2 laser/Scanner Rotation Error
ACTION:
2. Turn the printer off, and then turn the printer on.
3. Reseat the cables fort the Laser / Scanner Assembly.
4. Replace the Laser/Scanner Assembly
Sep 21, 2009 | HP Photosmart 8150 InkJet Printer
SCANNER ERROR 12
in my laser jet M1005 printer showing the scanner error 12. kindly help me how i can solve the problem.
E-mail : jkmeher@yahoo.com
Jul 13, 2009 | HP LaserJet M1005 Printer
I don't know this model in particular, but most machines have a switch underneath the automatic feeder, on the left side of the contact glass.
Please rate solution:)
Apr 21, 2009 | Dell 1600n All-In-One Laser Printer
Printer is saying scanner is locked, unlock scanner
In the section where the paper exits the printer, there is a blue latch. Pull it towards you. It does take a little pressure to pull. You may need to press cancel a few times. That should clear it out. If it doesn't, The scanning unit assemply needs replaced...or the printer itselft which ever is cheaper.
Jan 28, 2009 | Dell 1815dn All-In-One Laser Printer
Scanner locked
Reach in the cavity where the paper comes out. In the top left far corder you will find a blue sliding switch. Pull it forward and press cancel.
Jul 23, 2008 | Dell 1600n All-In-One Laser Printer
Unlock scanner issues
tab? what tab are we referring to? I know this printer quite well, and I'm at a loss for understanding this aspect?
Jul 22, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
369 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
