Question about Philips 32PW6506 32" TV
Philips 32PW6526C Picture problem
The picture gets smaller from the bottom until it is half black and half picture. After a while the set turns itself off. Anbody know what this could be? thanks,
  • swiftnick Mar 09, 2009
    IT WAS THE PAINTER BOARD
    Genius:
  • Philips Master
  • 1,550 Answers
Dried capacitors around the vertical IC output
Posted on Mar 06, 2009
Only have part of picture on phillips 50tv
Are you missing the top portion of the picture or the bottom portion of the picture? looking inside the TV will reveal two modules to the furthest left of the inside. These are the upper and lower Y buffer modules. Replace the top one if missing the top half of the picture or the bottom one if missing that segment. Usually you can find good used parts on Ebay. Or Shopjimmy.com.
PHILIPS 50PF9631D 37 BUFFER BOARDS LJ41 03883A LJ41 03882A
Apr 05, 2015 | Philips Televison & Video
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Bottom half of screen black-out
I would replace the lower Y buffer. Part number 996500032640. Goodluck.
Jul 05, 2010 | Philips 42PF7220A 42 in. Plasma Television
Picture does not stay on when set is turned on
its a switch fault, you need to get a tecnition but cheaper buying a new tv,hope this help
Jan 24, 2010 | Philips Magnavox 27MT5405 TV
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Picture green and not clear, getting smaller, shutting itself off
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Philips 32PW6506 32" TV Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
