I have a wm 2032 hw that i haven't hooked up to water yet. But I have hooked up electricity to it. It seems as though all the lights work except the door lock light. It also won't do anything, but I assume it's because there is no water in it. Is that why the door light is not on?
  • 15,935 Answers
Yes. the light wont turn on until the cycle begins and there is confirmation the door is locked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
I can't get any my system to heat the water. The main electricity went off and on again and maybe it needs resetting but button not responding
Try unplugging the unit for 5 minutes and see if it resets, if no joy you have a possible burnt control board due to a power surge.
Aug 09, 2016 | Water Water Heaters
My LG WM 1812CW turns off soon after the first spin. No error message.
Seems that the main panel is defective. The fault suggests that the program controller or the processor is malfunctioning specially when it works for some time. If you can check on the +5 volt to the processor , the power supply factor can be established as a faulty supply or a blown mains capacitor can also shown this fault .
So remove the panel and check the components for any visible signs.
Jan 14, 2013 | LG WM-2277HW Front Load Washer
My LG WM227 HW is leaking water fromthe bottom of the machine while machine IS NOT in use!
You have a leaking water valve or drain hose. You will need to have a qualified technician to help you find the problem.
Good luck
Jun 10, 2011 | LG WM-2277HW Front Load Washer
My LG is a few years old, Model WM1832CW and seems to work in all modes except rinse. It just started this morning and sounds like its slipping and grinding and won't pump the water out. any suggestions....
Replace the pump motor. On your model, it can be done without removing the front panel. Open access door at bottom left of front panel. drain water out small hose. remove screw from plastic recess and use putty knife at side of recess to remove plastic recess. remove screw holding pump. pull machine out 2 feet from wall and tilt it back to rest back edge against wall. depress plastic tab in base to release pump. remove hoses and unplug electrical connection to pump. remove 3 screws holding pump motor to pump housing. install new pump motor and re-assemble.
Nov 27, 2010 | LG WM-1832C Front Load Washer
I am getting a FE erroe on my LG WM-2277 HW Washer? What Part do I need?
Hi
Thanks for using FixYa. FE is Overflow error which means that the water is overflowing and the water level frequency is over 213. When FE error is displayed the drain pump operates to drain the water automatically. To resolve this issue you’ll have to check the water inlet valve and pressure sensor which can sense the water level in the tub, if any of this goes bad overflow occurs. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | LG WM-2277HW Front Load Washer
My WM 2455 HW washer won't start washing. It
my washing machine will not turn on. it has power but will not turn on
May 07, 2010 | LG Washing Machines
Does not spin
I disconnected the washing machine completely for a couple of hours.
Then turned it on again with no clothes in it. And wonders..... it started up again.
Feb 03, 2010 | LG Washing Machines
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
