Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Maintenance mode on a MFC-240
I know its menu ---> black ---> up three times to get into maintenance mode, but what are the commands?
brother doesnt help at all.... of course.
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC 640 CW
mike,
just press menu then start bk-copy then fourtimes arrow-up quite quickly one after another to get to the maintenance menu.
Posted on Mar 26, 2008
jtuminaro
  • 56 Answers
SOURCE: Replace Fuser error will not go away
With in 2 seconds you have to hit Menu,*,2,8,6,4
Continue even though you hear the 3 beeps.
When it does into maint mode press 88
That is parts counter reset
Scroll to the part and hit ok.
Press 99 to exit Maint mode
Posted on Jan 15, 2009
eliza_syafik
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
clean unable 46,see troubleshooting and routine maintenance chapter in user guide.Plase help me to splve this problem.
Posted on Aug 12, 2009
pineworks
  • 4041 Answers
SOURCE: brother mfc-7420 - unable to print
OK Try
Solution:
  • Machine off
  • Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
  • Press 80
  • Press the “mono start” button several times until you see “purge: xxxx”
  • Press “2783” in order to reset the purge counter. You will see: “purge:0000”
  • Press the "stop" button.
  • Press “99” to exit the maintenance mode.
All the best
Posted on Jan 30, 2010
SOURCE: Brother MFC-260C no black ink
i have the same problems....any solutions?
Posted on Feb 05, 2010
Maintenance mode in brother mfc 5910 dw
Robbin, your anwer is wrong, those kind of codes are usually not provided in the owners manual. I had a bad inyector obstruction problem on another Brother and the support provided me a maintenance code to access a hidden menu with "heavy" cleaning options that don't appear in the manual.
Feb 18, 2013 | Brother MFC-J5910DW Color Inkjet...
Won't print black
TRY CLEANING THE INK CARTRIDGE. If it doesnt work, go to service center with the printer.
Jun 30, 2012 | BROTHER INTERNATIONAL CORPORAT BROTHER...
Unable to print 32 printer brother mfc 9490cw
Unable to.....
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine
Sep 15, 2011 | Brother MFC 6490CW InkJet Printer
I'm receiving error message 46 on my Brother printer, MFC-465CN. I know that it means the ink absorber box is full. How do I solve this problem?
Welcome to Fixya. To fix error 46 on borhter printer please follow the steps below.
- FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
- Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Thanks for using Fixya.
May 04, 2011 | Brother MFC-465CN InkJet Printer
Brother mfc-21c....says, unable to clean..see troubleshooting and routine maintenance chapter...
Try running a purge count through the maintenance menu. You can enter maintenance mode by pressing: Menu> * 2 8 6 4 Press 8 0 Scroll down to purge count value. You should get there after pressing the down key 24 times. Press 2 7 8 3 to reset the purge count. The printer will then restart. Then try printing again.
Jan 03, 2010 | Brother MFC 210C All-In-One InkJet Printer
Have a brother DCP- 115C and had a paper jam, I removed the paper from the printer cleared the jam and now printer is telling me Unable to clean see Trouble shooting and routine maintenance in users...
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
(for printers with numeric keypad):
Resetting purge counter on: MFC-620CN / MFC-420CN / MFC-410CN / MFC-210C and FAX-2440C:
1. Enter machine maintenance mode (on MFC-210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode.
2. Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3. Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4. Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5. Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6. Press the 9 key twice to return to the standby state.
Dec 11, 2009 | Brother DCP 115C All-In-One InkJet Printer
I have a brother mfc printer I purchase a new black ink but it is not working the color works but black doesn't I've tried cleaning it but luck in suggestion?
The print head is clogged.
Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 20, 2009 | Brother MFC-5840CN All-In-One InkJet...
MFC-490CW two ink colours just not printing, it still prints biut just with black and blue, tried cleaning them the normal way but they still wont print. Cant get into maintenence mode to try better...
Powerful cleaning is: Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode (all lights will flash).
press 7-6-4 and OK (or start-black-copy).
Nov 10, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printing below standard
The problem could very well be clogged ink or air bubbles. There's no need to perform the regular cleaning any more as if it didn't solve the problem in the first few tries, it wont help, more force is needed.
You can perform a powerpurge (takes more ink, uses more force, solves more clogged ink), to perform it, follow these steps:
  • Enter maintenance mode, press menu, 2, 8, 6, 4 quickly (in two seconds).
  • When the buttons are flashing and the display says Maintenance, press 7, 6.
  • The display should now say "CLEANING ALL", press 3.
  • Now it should say something among the lines P_PURGE or POWER_P. Press Mono/Black Start.
  • After cleaning is done, you will get back to Maintenance. Press 9,9 to leave service mode again.
If the problem isn't solved now however, chemicals would probably be needed to solve it, as this is pretty much the only "function" you can use.
May 26, 2009 | Brother MFC-260C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
1,427 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
