Question about LG WM0642H Front Load
How do I reverse the dryer door on my front loader LG
Do I just remove the screws or is there elecronics invlolved
  • 1,543 Answers
No electronics involved in reversing a LG dryer door. On a difficulty scale of 1 - 10, it rates about a 2. Go for it.
Posted on Mar 15, 2009
Want to switch the side the door opens on my lg dryer
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
Feb 02, 2013 | LG SteamDryer 7.3 Cu. Ft....
Reversing dryer door on Maytag 4000 front loader. I'm not sure how to switch the hinge once door is removed from dryer...? Thanks, Ledge
on the opposite side there are two plastic fillers, take out, take the screws of the hinges, lift out an up, screw hinges into where fillers where, screw fillers into where hinges where. Hope this helped Tim
May 08, 2011 | Maytag Dryers
I need to know how to get the front off of my lg dle0442w dyer.
Disconnect power then using a putty knife, push the blade in the seam between the top panel and the front panel against the retaining clips 2 3/4" (7 cm) from the sides. Lift the top panel while doing this to release the clips and raise the pane.
Open the door and remove the two screws at the bottom of the door opening.
Remove the screws securing the top of the front panel to the cabinet then pull the panel slight away from the cabinet and disconnect the door switch wire harness. Pull the front panel completely out and set it aside.
Reassemble the dryer by following the disassembly steps in reverse order.
Feb 21, 2011 | LG DLE0442 Electric Dryer
My dryer does dry my clothes... thier is not hot air coming out what could be worng?
Could be the element the safety's or some sort of sensor. To disassemble remove the top first by removing screws in rear. To take off the control remove to screw on each side of the back. All connectors are color coded. Cannot screw up reassemble.Lift control out and up. Control board has 4 screws and is replaced as a unit. Keep the selector knob.
Removing and reversing the door
Remove the screws from opposite side and then remove the latch pull out the latch no wires are there. Take the door off and reverse it then replace the latch and shorter screws for extra holes.
Remove the front:
Disconnect the dryer light and door switch wires. Move harness out yer way. Remove 2 screws at the base of the door opening and 4 screws along the top. Tip the panel to the front and lifts off. Next remove the top bracket 2 screws each end. Lift brace up and off.
To remove the shroud/panel 4 screws are removed and lifted up and pulled forward. Disconnect the wire to the humidity sensor.
Remove the belt from idler and yank the drum out. (The belt goes under the tensioner then over the pulley then release it and the spring holds everythang in place like a DOT dryer.) The grooved/ribbed surface goes to the tub side. themobilian_672.jpg
LG dryer service Manual
Jan 04, 2011 | Kenmore Elite HE4 Electric Dryer
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
Cracked drum lg tromm dle2512w dryer. is it worth replacing? dryer is about 3 yrs old
I'd say yes, especially if you replace it yourself to avoid a service call. Top needs to come off (screws at back, then push top back 2 inches and lift off), remove front, remove 4 screws holding front bulk head / front rollers, slip belt off tension pulley, remove drum, reverse to install.
Sep 25, 2010 | LG DLE2512W Electric Dryer
How do I remove the front panel of my front loading LG dryer
Open door. Remove phillips head screws at 5 and 7 O'Clock positions. Close door. Use putty knife to push in clips (2) relaeasing top. (located in seam where top meets front panel) Swing top back. Remove two phillips head screws at top of front panel. Unplug light and door switch. Tilt front panel forward and lift off bottom tabs.
Sep 25, 2010 | LG DLG5988 Gas Dryer
Cracked Drum on LG Dryer Model #DLE2512W
I had a 2514 with a similar problem. Cracked drum. This is what I did to fix it. With the new drum. No noise at all.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Feb 10, 2009 | LG DLE2515S Gas Dryer
Door opens on wrong side
I don't think you can on a front loader washer.. on your dryer you can see how they have screw covers for interchanging, but on washer there are none.. sorry.. good luck..
Jan 21, 2009 | Frigidaire ATF6000ES Front Load Washer
LG WM0642H Front Load Logo
795 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
