Question about Kodak EasyShare V610 Digital Camera
V610 camera wont turn on
My camera makes a weird noise when I turn it on and then it immediately shuts off. It doesnt run on battery power and I have tried plugging it in and it still won't work. I don't know how to fix it.
I figured out that the rechargeable battery inside my camera is dead so I have to buy a new one because it is like 3 years old.
Posted on Mar 07, 2009
Kodak V610 Easyshare won't turn on
You have a board power supply issue which would be covered under warranty. (Hopefully you still under warranty)
Aug 19, 2007 | Kodak EasyShare V610 Digital Camera
Okay.. I Turned The Camera Off To Let It Charge Over Night. When I Came To Turn It Back On, It Wont Power On. When I Put The Charger Back In, It Lights Up As Though It Is Still Charging But It WILL NOT...
Haha,maybe there's a accident happened at the night ,so the battery for Kodak EasyShare V610 is still charging as begin.You need let it charging until it is full with power then we can confirm what's the problem definitely.
Feb 10, 2011 | Kodak EasyShare V610 Digital Camera
Camera will not stay turned on despite new battery. Immediately prior to this, view screen was black and took black pictures.
The shutter in the camera is not opening to allow photographs, the motor that controls aperture has malfunctioned or the ccd sensor is not working, sometimes the systems controller board that the ccd is plugged into becomes detached and needs to be reseated back into place to make it operational.
Feb 06, 2011 | Kodak EasyShare V610 Digital Camera
Why does my camera turn on, make a weird noise and
hi. you have problem in lens unit and the weird noise come from to focus gear.maybe you go to the beach or dusty place thats why the said dust or sand goes into lens gear. If you can open and try to clean its better but if not bring to service center and request for cleaning and adjustment.
goodluck my friend
Jul 13, 2010 | Casio EXILIM 10.1-Megapixel Digital Camera...
Error #E45
For this problem try the following:
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Oct 02, 2009 | Kodak EasyShare V610 Digital Camera
Kodak Camera V610 easy share
Hi!
This is what I need you to try..
If you're using a 5v ac adapter to charge the camera's battery - please hook it to the camera WITHOUT THE BATTERY in it. The 5v ac adapter can be an alternative power supply.
Turn on the camera - check if it would do the same thing - like lighting up, making a noise (attempting to extend the lens) and closes. If it does, the camera needs to be sent in for repair.
visit www.kodak.com/go/itg to arrange repair
If you are using a photoframe dock2 or camera dock series 3 to recharge the camera's batt - use its 5v ac adapter. It will work with the cam. Make sure, the batt is not in it to check the cam's condition, isolating the possible interference of the battery.
If the camera works fine - when the AC adapter is attached, no battery in it - consider buying a new battery.
V610 is a very nice camera, but it was manufactured in 2006. If you have not replaced the battery yet, it might just need to be replaced. Even Li-ion rechargeable batteries wear out eventually - it can only last up to 300 charging cycles.
If you're using a batt that is less than a year old, the cam might just need to be sent in for service.
Nov 24, 2008 | Kodak EasyShare V610 Digital Camera
Olympus FE-280 not working properly
the lens could be the problem.. probably need to send to repair before the warranty runs out
Aug 28, 2008 | Olympus FE-280 Digital Camera
Kodak EasyShare V610 Digital Camera Logo
260 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
