Question about Vehicle Parts & Accessories
Alarm/immobiliser cant turn off alarm/immobiliser on rover 214 need to know how to reset the immobiliser.
  • Anonymous Mar 27, 2009
    i got a new battery fitted in my key and my alarm went off after that i came home and started my car which whas been a week now can ould not start it has been a week now can anyone help
  • 165 Answers
I cant help you but i need to send you by fax the information,email me reynosaelectronics@live.com.mx send me your fax number.
Posted on Mar 17, 2009
How to bypass immobiliser system on a rover 214?
These systems are designed to be hackproof, to make it impossible to steal cars. Chances are you can't bypass it, and that's a good thing.
Oct 28, 2014 | Vehicle Parts & Accessories
How to disconnect immobilliser on a land rover discovery 2001
Engine immobiliser must be disabled by a Rover TedtBook. Most likely only your local dealer will be so equipped. There are ways to work around or through thus common isssue. Be sure youve done the following before dropping the bucks at the dealer:
Replace batteries in your remote
Resync remote (instructions in your owners manual)
Try resetting the alarm ECM by disconnecting negative battery cable, turn ignition to second position, leave drivers door open, then reattach your negative lead, shut the hood, get in the drivers seat, turn off the ignition then attempt starting. Hoid and drivers door must be shut when you attempt to turn it over.
Last but not least therd is the EKA procedure. Step by step instructiona available on this and many other sites. Google "EKA procedure" adding your model and year in the search box.
Good luck. Feel free to message me directly if you are unable to find the instructions.
Jul 12, 2014 | 2001 Land Rover Discovery Series II
P38 range rover immobiliser wont relisee
Is it possible to disable it with a Rovercom, i had my alarm disabled with it becuse it kept going off on its own , i found the problem but who takes any notice of a alarm..
Apr 26, 2012 | 1997 Land Rover Range Rover
My rover 414i immobiliser will not turn of and i cant start my car
i have a problem with my rover 414i year 1995 in the moment that i put the radiator cable in the heat cartridge the motor loses engine and turns off automatically. Please help me
Jan 06, 2012 | Rover 400 Cars & Trucks
Hello ive got a rover 214 1999,,and the remote locking wont work at all,,it used to work if i pressed it lots of times but now its totally given up the ghost,,ive changed the keyfob battery and that hasnt...
Rovers have so many different variations - here's the bible for Rovers. Download it (Free) and keep it nearby. It's a priceless tool -> http://www.landroverresource.com/
Mar 04, 2011 | Land Rover Freelander Cars & Trucks
Key fob would not open 1995 discovery ,used key in door then alarm went off ,after a few seconds alarm ceased then put key in to start engine and got nothing now cant lock doors with key but red light is...
The red light means the Immobiliser has not been turned off, the deactivator in the key must not be working correctly, visit your local land rover dealer who will be able to make sure the key is paired to the car correctly, otherwise you may need a new key.
Feb 11, 2011 | 1995 Land Rover Discovery
I have a 1998 discovery got alarm key wet and now i cant turn it off how do i by pass the alarm so i can start my car
if it is the factory alarm then it cannot be bypassed.you can ie send the ecu back to a company here in the uk to have the immobiliser bypassed or you can have two new fobs reprogrammed from your old fob,email me marcusloud@blueyonder.co.uk and i will pass company details on.
Nov 18, 2009 | 2000 Land Rover Discovery
Hi ,, I need to know if my alarm is turned of or if the module is bad in my land rover freelander. can some one tell me where i can find it
The Haynes manual says the following:-
The central contol unit (CCU) is located in the back of the fusebox below the driver's side fascia. If a fault develops you have to use a LR delaer to use the diagnostics. The unit controls the anti-theft, windscreen wipers, courtesy lamp delay, door opening warning lamp, key-in alarm,rear foglights, light-on alarm, seat belt warning, handbrake warning, rear screen wiper, tailaget window and many others.
Section 12.20 has a whole section on the alarm. The key fob alarm handset contains a transponder which talks to a reader in the ignition switch. So the immobiliser will cut in if the ignition key and the key fob are not on the same key ring.
Mar 31, 2009 | 2002 Land Rover Freelander
Alarm and interior light draining battery
Without testing it's hard to say. Try changing the small battery in the immobiliser, if equipped. This may or may not work.
Jan 23, 2009 | 1995 Land Rover Discovery
Immobiliser wont go off , wont unlock the doors.
There is a way to override the code, however you need the code number. The only other way is to sit in car with door shut, play with the central locking button on dash, locking and unlocking. While doing this occassionally turn the ignition on and off. If you do it long enough, you may find the immobiliser light goes out, if it does, quickly start the car.
TL
Jan 13, 2009 | 2000 Renault Sportwagon
Vehicle Parts & Accessories Logo
1,043 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
