Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy 110000 btu fan motor needs front bearing , shaft id fine i took motor apart by grinding weld off of end bell. i am a motor repair expert, retired do not have accses to a lathe or i coud make a bearing/bushing.
  • 188 Answers
You may want to contact Master Parts, they may not have the bearings. However, they may have that motor at a reasonable price. You can contact them at 800-446-1446 or online at I hope this helps you.
Posted on Apr 09, 2009
How do you seperate a kohler motor from generator on a miller welder?
if by asking this im assuming the generator is face bolted to motor , if this is so , to save from having another front bearing , the gen stator is directed attached to motor shaft , on the far end under end bell cover is the end of shaft , a long bolt goes thru gen shaft to screw into motor shaft , MARK/photograph all the wires you unhook helps a lot when puting back together
Aug 05, 2014 | Kohler Replacement Engine Part Pa-64711...
I tried pull the cord stuck took it apart spring ok.the shaft from engine stuck,
Sounds like you have a bearing failure, eithe big end or crank shaft bearing. When they go they quite often knacker the piston and cylinder too as it can put them off square. Remove cylinder and the problem will be easy to locate as you can see the big/small end bearings and check for cylinder damage. Often the cost of repair far outweighs the value of the equipment.
Apr 07, 2013 | Husqvarna 128 LD Weedeater
115,000 btu reddy heater, 5 hrs used in sprayfoam-grinding environment. stopped working. when plugged in, only hums for a few seconds, then stops. how can i fix that?
First, remove the top cover. Inspect for a varmint nest. If clear, manually spin the fan. If it does not you either have a broken rotor that is binding or you have a bad bearing.
If it spins freely, apply power- see if the motor runs with the top cover removed.
If YES, replace the top cover. Its possible that the top is binding the fan.
If NO, the start capacitor is defective. The cap on R115 is internal and is not servicable.
Reading material about a hummer
Nov 04, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
A.O. Smith pump c48k2pa105c5 runs fine but late in day has started to give a periodic high humming sound. Goes away, comes back, goes away, etc., but is still running. Unit is about three years old. Going...
this is a common problem with this motor, what has happed is the end bell has gone bad.(holds the front or rear bearing) you will need to find out witch one and replace it, good luck finding one, so look for your local pool pump motor repair guy in you area. and have him rebuild it. i have them used in stock, but i do not ship . the total repair cost is 75.00 with a free shaft seal.. if'n your handy and you take it apart and find that it has the oring in the back end bell.. there is a guy selling them on ebay, look for the pool pump repair puppy. there like 2 bucks with shipping. thats a kool fix !.. jay Florida .. oh and good luck. cuz it's kool to fix it yourself !
Jan 06, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
Will the fan on the reddy heater not run if the ignighter is bad? When i plug it in the fan doesn't run.Do i need to replace the motor?
The fan motor runs regardless of the igniter as it is also the fuel pump. Possibly you may need to replace the motor but try this first. Remove the top section of the heater this exposes the fan motor, try spinning the motor by hand,it should spin freely if it does not try some light oil in the front and rear bearings of the motor and turn it by hand until it frees up. You may need to do this several times!! Now that it is spinning free put the heater back together and try it out. If it does not work a new motor is in your future. Hope this works out for you.
Dec 26, 2010 | Reddy Heater-30-55,000 BTU Variable
Hello i havent Used my ready heater 60000 btu since last winter. It was working fine when i unpluged and emptied when i plug it up i hear a hum and nothing else no blower or anything....could ude...
The fan motor is setup...
Tear it part and get some WD-40 worked into the motor at the shaft end... then when you get it spinning freely... get some light motor oil worked into the bearing...
Works best if you can tip the heater back so the WD-40 and oil naturally run back into the motor...
Dec 13, 2010 | Reddy Heater-30-55,000 BTU Variable
When I plug the unit in, the fan turns very slow, and I smell fumes, but the unit does'nt turn on
I am not able to give you a solution, but will put forth some possibilities for you to check.
  1. Spin the fan manually. No power, please. If the fan spins freely, and no grinding is heard or felt, then the starter capacitor or starter relay (whichever equipped) is defective. Internal capacitors are not serviceable. Replace the motor.
  2. If the fan does NOT spin freely and/or binds, either the rotor (air pump) is broken or a motor bearing is bad. The rotor is replaceable, the motor bearing is not serviceable.
If you decide to repair the heater as described then the air pump pressure must be reset, in either case, in order for the heater to burn properly. It is a simple process. Follow this link for instructions
Nov 02, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Remington 60 portable forced air heater 60,000 btu
I had the same problem. I took the nozzle head off and blew through it with air. I also blew through the air line, this is the one that goes to motor. It has worked fine ever since.
Dec 16, 2008 | Reddy Heater-30-55,000 BTU Variable
Loud grinding noise when dryer is on aslo blew fuse last night
sounds like bearings in your ctd40
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Dec 09, 2008 | Hotpoint TDC32 Electric Dryer
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
228 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
