Question about Lexmark T632 Laser Printer
202 paper jam
Lexmark t632 printer tells me to open back cover "paper jam 202 " however I cannot see any paper jammed. turned printer on/off, checked trays, how to reset as I cannot see paper jam.
  • hallsrxdme Apr 09, 2009
    Can see plastic melted to the heat stip on the do we get it off? Keeps jamming!
I have this problem too, but the 2 sensors on the fuser are not stuck and seem ok to me. Any other suggestions?
Posted on Nov 16, 2009
    Problem Solver:
  • 10 Answers
Hit the go button. Sometimes when a jam is removed the printer doesn't reset itself back to ready status.
If that works, then you will be all set. If it does not then your fuser may need to be replaced. There are 2 dip switches on the fuser that can break when removing this type of jam. They kind of let the printer know when a page has exited the fuser...
To check this you can remove the back door assy. On the redrive, (which is the part that the back door covers) there will be a gap .... if you shine a light into that gap you can see the fusing assy. The 201 and 202 sensors are located on the left and the right side of the fuser. Check to see if one of those flags are broken or out of place.
Hope this helps...
Posted on Mar 11, 2009
  • 85 Answers
There are 2 paper sensors on the fuser, sometimes they get stuck down. you may need to remove the back(redrive) assembly to see them better. You are looking for a lever about 1/2 inch tall in the paper path
Posted on Mar 14, 2009
  • 101 Answers
Try to find paper or peice (bit, partm particle) of paper under back cover.
Posted on Mar 07, 2009
Paper is jammed in printer under the heating element and I can't get it out
remove the back cover, 2 screws holding the redrive (back) assembly.
You will have access to the fuser, again held with 2 screws. Disconnect cables going to the fuser, remove and clear paper. Examine the surface of the rollers, bottom has rubber surface. If surface is showing ripples in the rubber, you may need to replace it to prevent further jams.
Oct 21, 2011 | Lexmark T632 Laser Printer
Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path. Open the scanner unit or the printer cover.
  4. If you can see the paper jam, the cartridge area should give you enough space for your hand to reach on the jammed paper in the printer.
  5. Carefully remove the paper jam and make sure not to tear or leave torn pieces of paper in the printer. It can cause future paper jams.
  6. When the jam is cleared, close the printer cover.
  7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
  8. When the printer turns on, try to print again.
Aug 19, 2011 | Lexmark C533DN InkJet Printer
202 papier vast open both doors from the lexmark e340 printer
Please click on the link below to resolve paper jam problems. To prevent paper jams, please make sure that the paper settings on the printer is in sync from the application (e.g Microsoft word).
If you need further assistance please contact Lexmark Technical Support.
Jul 27, 2011 | Lexmark E340 Laser Printer
Paper jam with no paper in it
Click on the link below and follow the steps to clear Paper Jam Issue.
Paper Jam
This link is useful as it has lot more issue resolution covered for your printer.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 29, 2010 | Lexmark T632 Laser Printer
Rear door paper jam
Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jul 22, 2010 | Lexmark X646e All-In-One Laser Printer
202 printer jammed error message appears, but could not locate
Here's an article in the Lexmark website on Error: "201 Paper Jam" or "202 Paper Jam". This will guide you on where to locate the cause of the problem. Follow the instructions. But if you're having a really hard time locating it or you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jun 28, 2010 | Lexmark C762dn Laser Printer
202 paperjam open rear door. My printer did have a paper jam and we removed all the paper we could find, but that message won't go away and it hasn't worked since! HELP!
Hello and Welcome to FixYa
Start by following the steps below to get the paper out from the machine.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
If that doesn't help then you would have to start taking apart the machine to find the jammed paper and remove it, its not something a just anyone should do unless you have experience.
you may have to take the machine to a repairer to get the jammed paper bits out of the machine, if you don't see paper jammed in the machine it does not mean that there wouldn't be a paper jam somewhere in the unit along the paper path. Some of the switches or sensors might have gotten stuck.
Jan 04, 2010 | Lexmark T630 Laser Printer
Lexmark Optra S 1625 202-paper jam open rear door
well with my experience with my opinion crappy lexmark printers there is a senser on the fuser behind the cover it could be jammed down saying there is paper in the fuser when there isnt try lifting it and then flicking it down a few times to work it loose so it springs back all the time and then re-assemble the printer and try it now. hope that works for you had the same problem at work with another model and that is what was wrong with it. good luck
Sep 01, 2009 | Lexmark Optra S 1625 Laser Printer
202 Paper Jam om Lexmark c510
1. Make sure the printer is on.
2. Raise the scanner unit.
3. Remove both print cartridges.
4. Make sure the cartridge carrier lids are closed.
5. Close the scanner unit.
6. Press to turn the printer off.
7. Disconnect the power cord from the wall outlet.
8. Plug the power cord back into the wall outlet.
Jun 09, 2017 | Lexmark C510 Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Lexmark T632 Laser Printer Logo
1,789 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
