Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I can't save a file from my Mac to SanDisk 8G Cruzer Micro USB
I can't save a file from my Mac to SanDisk 8G Cuzer Micro USB.
    Master:
  • 404 Answers
You have to have the cuzer mac formatted using the disk utility.
Posted on Mar 07, 2009
I have a sandisk usb "mac format" and want to open
Do you mainly use it on a Mac? Do you want to use it for both Mac and PC? If it's the latter, you can format your USB drive on your mac using disk utility and formatting it as ExFAT. This way it will be recognized on both Mac and PC and you can save files onto it as well.
Where if you formatted it to Mac only you will only be able to write to it on Macs and not PCs.
Hope that makes sense
Sep 28, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Why can't I open any DOC files saved on any Cuzer Micro? I does open files from Power Point.
right click on the file select properties then on the security tab you must have full control if you dont click on the advanced change permissions tab
also you must have the program that made the files on your computer
this might vary between certain documents, programs and operating systems
hope this helps you
Sep 15, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do you use a sandisk cruzer micro usb 2.0 flash drive
insert your 2 gb cruzer into a usb port click start all programs accessories open windows explorer my computer you should see your drive click to open it from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to scan disc then drop them
or if you are downloading from the internet once the program/files starts to download an option will open and ask where you want to save it or run it also browse click on the browse to save it to your 2 gb cruzer
hope this helps
Jul 10, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to format my 8g cruzer micro USB
Go to my computer and right click on the USB Flash Drive then left click on format
Nov 30, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Pendrive has stopped working its a Cuzer 16GB
try restartng the comp . if it do not work ,try using the pen drive on another comp.
Mar 24, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer 16gb, Macformat, tv won't recognize
Dowload codec Klite pack, via Google, and open the files with that media player, the tv should then pick it up, seeing as its a multi codec reader program, Hope it helps
Jan 16, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How to use flash drive
Cruzer Micro is an USB external memory where you can store files.
It is automatically detected and installed on all Windows OS from Windows 2000 onward, same on Mac OS and recent Linux versions.
All you have to do is plugging the device into USB.
After the flash drive had been automatically installed , it will be displayed under Computer as an external disk.
You can copy and transfer files using Cut, Copy and Paste functions, or Send to function in windows, or the file manager, depending on the OS used.
In Windows, before unplugging the memory from USB , it is better to turn off the computer or use the 'safely remove USB' function located near to the clock, on the lower right hand corner.
Read also the documents below:
Introducing the Cruzer Micro
Find Answers || BeCompliant Corporation
How to Use Sandisk Cruzer Flash Drive
May 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I really need to recover files from my sandisk cruzer
Have you tried this? restart your computer and plug your USB in again(this helps to clean the buffer), see if you drive can be recognized.
If you still can't access the data inside, try this data recovery program Wondershare Data Recovery. Get the program here,
Windows Data Recovery (Windows Version)
Mac Data Recovery (Mac OS version)
Take care - Before those items are recovered, stop saving more files to the device in case the file data are overwritten!
Nov 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Nothing on my cruzer micro!
hai,
check that the files in ur flash drive is hidden or not.
for that in folder options change the view settings to view the hidden files.
still u cannot find ur files, use any file recovery software.
to help u find one click here
good luck
Please don't forget to rate or accept the solution
Jun 16, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Micro 8GB cruzer
Save all your files on your computer before doing this.
Uninstall U3 from settings on launchpad.
Format your USB. Do not Quick format.
Reinstall U3: http://www.sandisk.com/Retail/Default.aspx?CatID=1411 (only works with Sandisk)
Drag your files into the USB. No more problems!
If anymore problems, reply!
Hope this helps!
Nicholas CHUM
Apr 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
209 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
