Question about Pioneer Premier DEH-P960MP CD Player
2nd display background changes from black to white at intervals
I bought a used 2005 Honda civic si hatchback with about 60,000 miles. This radio had been installed (it appears to be a professional install, with amp for sub only). After about 3 months (4,000 miles), my 2nd display started appearing to be switching/changing from black to white (or as if it were changing from a nightime to daytime display) on an interval basis of approximately 15 seconds. Yet, after any button is pushed the display reverts to the black (nightime) display, & will remain with this display for about 30 seconds before reverting back to the 15 second intervals. I have an owners manual of of the internet, but have been unable to find anything to solve this problem.
    Problem Solver:
  • 5 Answers
Try this - look for a reverse mode on the unit and turn this off. This is exactly what my deh-p9600mp did until I turned off the reverse mode.
Posted on May 12, 2009
  • 3 Answers
Hi:
The change in the backgroung color of the OEL display is totally normal. This funtion lets the display works in two modes rather than only one to prevent OEL display damage, it is like a screen saver. I had the same model I bought
Posted on Mar 14, 2009
  • alpizarluis Mar 14, 2009
    a few years ago and when I start to use this receiver I ask my self the same question. I think there is no problem at all. Hope this help!!
The new timing belt jumped
no it is not. (late answer) is this a double post?
all timing belts jump,
1: every 60k miles for most. ever read the service list.
some top quality belts go bad at 100k miles. so.....????
Honda uses an "interference" engine design.
do not skip this service, or the whole engine can grenade !!!
honda quote, pasted.
However, since these engines utilize an interference design, it is highly recommended to at least inspect the timing belt at 60,000 mile (96,000 km) intervals. It is an even better idea to replace the belt at these intervals. On 1990-94 models, Honda recommends the timing belt to be replaced at 90,000 mile (144,000 km) intervals. On 1995 models, the recommended interval is 60,000 miles (96,000 km).end quote.
and if the last guy put in a POS china belt, well, you are hosed.
no name belts are junk, never ever use one,
BTW i run Gates belts.
Oct 23, 2013 | 1990 Honda Accord
60,000 mile maintanence
If you are wanting to know what services are due, the best thing to do is check your Owner's Manual. Different things may be due depending on how your Civic is equipped (engine size, transmission type, etc.).
If you do not have an Owner's Manual, you can download a free copy by signing up for a free registration at ownerslink.com. (The official site for Honda owners) You will need the VIN from your vehicle to register. There is a BUNCH of FREE information provided for Honda owners. Just click the following link:
Honda Owner's Link
Dec 08, 2011 | 2005 Honda Civic
I need the radio wiring diagram for 88 honda civic hatchback
1988 Honda Civic Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Blue
Radio Switched Ignition 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: N/A
Radio Amplifier Turn On Wire: N/A
Front Speaker Size: N/A
Front Speaker Location: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speaker Size: N/A
Rear Speaker Location: N/A
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Here can find the Stereo Wire Harness OEM Honda Civic 86 87 88 89 90 (car radio wiring installation parts)
Hope help with this.
Apr 26, 2010 | 1988 Honda Civic 2 Door
Does the 2005 Kia Sportage 4cyl timing belt need to be replaced at 40,000 miles?
No I beleive that the recommended interval is 60,000 miles.
Dec 09, 2009 | 2005 Kia Sportage
What is the factory recommended oil change interval on 98 Honda civic
If using Honda oil 5,000 miles If using non Honda oil 3,500 - 4,000 miles
Jul 28, 2009 | 1998 Honda Civic
I have a 1990 honda civic hatchback si with an 89 ZC DOHC black top engine.. the rear motor mount is cracked and each time i down shift the engine raddles.. how do i change out the mount? and if possible.....
You will need something to lift the engine so that you can take the pressure off of the mount. It sounds like your fuel pump may be wearing out and it is not responding like it should...The pump on the gas tank should be located on the top of the tank....Under the back seat....
May 07, 2009 | 1990 Honda Civic
Change the headlight assembly on a 91 honda civic si hatchback
I don't believe you do. You may have to take several of the clips or screws out, that also help to hold the bumper cover on , but that should be it
May 03, 2009 | 1998 Honda Civic
Honda civic hatchback
you have to change wiring harnesses and ecu then recheck timing u should be set
Sep 21, 2008 | 1990 Honda Civic
Pioneer Premier DEH-P960MP CD Player Logo
299 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
