Question about Marshall 15 Watt Guitar Amp
Amp questions what happends if you use a marshall guiter amp on a bass
  • 4,234 Answers
If you strike a low note too loud you risk damaging the speaker itself. The low note will cause hte speaker to extrude too far when loud and can either pop out completely or wear through the voice coil and short out the amp.
In short, don't do it.
Posted on Mar 06, 2009
What is the modern replacement speaker for Marshall 27115 bass combo
You would be Seamus?
Eminence are not a high-priced speaker. You could replace it with one of the bass guitar speakers here, like the large magnet CB15
Sep 26, 2016 | Bass Music
Marshall 600 silver series bass amp head
Hi, what speaker do you have connected directly to the head? What output are you using to go to the PA?
Dec 19, 2013 | Music
I have a marshall mb150 and sometimes it used to stop emitting sounds for a while but now in the sounds gets deemer and louder every now and then
A common issue with Marshall Amps are generally speaking a low resistor value cracked leg inside the power module, just open up the amp and with the amp unplugged from mains check by a little finger movement the big 2/3W resistors and possibly you will find that one or other will have a broken leg, also cold solder joints do this kind of issue, hope this helps...
Oct 09, 2013 | Marshall Amplifiers Marshall MB150 150W...
Hello, well i just bought this week an MB4410 marshall and it sounds a lil bit distored even at low volumes and on the clean modern channel, i just wanted to know if thats how the amp should sound like or...
First make sure your guitar can't "hear" the amp as the sound can rattle the strings and have a form of feedback. Stand with your back toward the amp for example. If that doesn't help, take your guitar to the dealer and try it on another of the same type... see if it does the same. Also where you use it, make sure nothing is rattling in the area that can fool you as to how it sounds...
Apr 10, 2011 | Marshall MB4410 Bass Combo Amplifier
Does anyone know how to make a bass knob remote out of phone line? What the color code? I have 4 different color wire here but i don't know what to do to make a bass knob remote.
It is NOT clear what you are trying to do... HOWEVER if you are attempting to extend a bass potentiometer remotely, you CANNOT use the four wire flat telephone line as it is unshielded and you will pick up hum.
Dec 04, 2010 | Marshall Amplification Marshall IBS Bass...
I am no longer able to turn on my amp. I was running a bass head through it a few months ago, and havent used it since. Now the amp wont turn on at all. I have tried turning the master volume down to 0,...
probolly all you did was run a head into another amp and just caused your marshall to overheat/overpower and blew your output transistor. i you drop the chassis out and look at the chip on the heatsink is it blown? also check all internal and external fuses.
Nov 24, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Can i fix one ampli marshall mg100 i had used my bass, and now my marshall have a very estrange noise
Well i know ive destroyed a guitar amp with a bass guitar before :-p this is why they make bass amps and guitar amps instead of just amps
Sep 25, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Is there a way to mod the hd100fx head for more bass?
You are ultimately limited by the available power of the internal amp. You can set controls for bass boost and turn off the treble but there is only so much power available.
HINT: If you are using speakers smaller than 15 inch, that will limit the bass as well. Use larger efficient speakers.
Aug 04, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall 15 Watt Guitar Amp Logo
147 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
