Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
DC14 Dyson vacuum, not vacuuming carpets, beater brush not moving but belt is intact
  • 3 Answers
Possible bad roller or bad clutch assy
Posted on Mar 07, 2009
How do I fix the carpet brush on my dyson dc14 vacuum?
this is what is is broken it is the clutch Dyson clutch belt assembly for DC07 amp DC14 900252 04 473
most likley needs to be changed it is also a good idea to change the roller brush at this point also
Dyson Dc 07 14 33 Upright Models oem 904174 01
Jun 12, 2016 | Dyson DC14 Animal Bagless Upright Cyclonic...
Beater bar making a loud noise
Our DC33 was making the same ratcheting sound immediately upon placing the cleaner/brush head on the carpet. We carefully pulled the beater/brush bar out of the vacuum. Once removed, we pulled the black plastic end nearest the belt off of the center rod. We discovered hair wrapped around each end of the center rod. After the hair was removed and the clean/brush bar was re-installed, the vacuum ran flawlessly. Hope it works as well for you as it did for us.
Apr 02, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Beater brush on Dyson DC14 getting no power
Hi There,
Alec from VacuumSpot here. The roller on a DC14 does not have a separate power supply the way it works is when the motor is running there is a belt that runs from the motor to the clutch and then another from the clutch to the roller.
As long as the floor selector on the front of the machine is set to carpet it will work when the machine is on.
Without seeing your machine I would suggest that there is something not quite right about the clutch. If I was to take a guess it would be that the clutch to motor belt is broken or slipped off. I have made a video showing how to check the clutch and the brush.
Dec 08, 2012 | Dyson DC14 All floors Bagless Upright...
My dyson has lost suction and the brushes do not rotate
Sounds like a broken belt may have been pulled up into the machine. Plan on replacing the belt and cleaning the beater brush. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt if needed, making sure the belt is put on properly.
Sep 11, 2010 | Dyson DC14 All floors Bagless Upright...
Brush not turning
The belt doesn't have to be broken to be non-functioning. If the belt is intact but stretched it won't turn the brush. You can get belts here:
Dyson DC14 Belts
Feb 14, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dog hair gets caught all the time in the belt drive spool, is there a fix for this other than having to pull it out all the time by hand? I have replaced the belt and the brush but this hasnt solved the...
My Dyson started making a loud noise when in "carpet" mode. After reading a ton of forums I thought it was the clutch assembly. Got a new one on eBay for a great price. Somewhat hard to replace, but thanks to this YouTube video, I was able to get it in: http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap and clean out the INSIDE of the beater bar (tons of lint and cat hair). I additionally sprayed WD40 in there.
It spins great now and in the end I think that's all I had to do was clean out the cat hair build up inside the beater bar. But now I have a new clutch & belts too. Hopefully won't have issues anytime soon.
Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The brush on my dyson ds14 will no move.
Can u turn the brush by hand with the vac off. Sounds like a bushing on the brush is siezed or mabe the belt is worn out and too loose. Try replacing the belt
Jul 25, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Beater brush won't spin but belt is intact and ok. Brush is clean and spins freely by hand.
For your beater brush to spin, you have to meet two conditions:
1) the vacuum cleaner has to be reclined (put your foot on the front and pull back on the handle).
2) The clutch actuator (the dial where you switch between BEAR FLOORS and CARPETS needs to be set to CARPETS).
If the brushbar/beater bar still doesn't spin after that, call the Dyson helpline, they will assist you. If you are saying that the brushbar isn't spinning because it is not picking up any dirt, you may have a loose internal hose, a blockage in the machine or the bristles on the brushbar are worn. Call the Dyson helpline for assistance.
Jul 11, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
251 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
