Question about Bose Lifestyle 38 System - white Theater System
BOSE 38-WHITE BACK:ERROR 801-LOUD SCRITCHING NOISE AFTER SHUT OFF
THIS IS A 4-YEARS OLD BOSE LIFESTYLE 38 DVD MEDIA CENTER WITH THE CAPABILITY TO STORE CD/DVD BUT NEVER USED FOR THAT PURPOSE. IT IS USED TO PRODUCE SURROUND SOUND ON 5-SPEAKERS. EVEN THAT HAS NOT REALLY WORKED EFFECTIVELY. WHEN TECHS WERE QUERIED THEY ANSWERD THAT THERE ARE VERY FEW TV PROGRAMS THAT SEND OUT A SURROUND SOUND SIGNAL. RIGHT NOW MY MAIN PROBLEM IS THE SCRITCHING SOUND.
    Novelist:
  • 90 Answers
Hello any cable or satelite tv show is now more comonly in high definition sound and video! and the techs are wrong because their are plenty of movies on tv including news channels that broadcast in surround sound ,but in order to get that surround sound you must either have a connection from the tv,s audio out or you can also out put the sound from the cable or satelite box out to your bose system as as the scritching sound where does it only happen when in surround mode or stereo mode ? if you play a dvd or cd does it still make noise? and can you be more specific on your terminology SCRITCHING not really shure what you mean by that word! thank you glenn mayer
Posted on Mar 07, 2009
Black and white
The Lifestyle 38 has no HDMI output. It all depends on what inputs your TV has, which cable set up would be the best for you. Assuming that your TV has an SVideo input, you indeed can use the SVideo output of the Bose system, to get the DVD picture on your TV. However you will need to connect the audio output of the TV to the TV input of the LS 38 to get the TV sound to play over your LS 38. In case you don't have an SVideo connection on your TV, you can use the composite output of the Bose system and connect it to the video input of your TV (yellow in and outputs)
Dec 10, 2013 | Bose Lifestyle 38 DVD Home Entertainment...
Tip
Bose LifeStyle 38 Video Mode
Bose LifeStyle 38 System Video Mode Change
Follow these steps to change the video setting from European to North American:
With the media center turned off, use the controls on its front panel to follow these steps:
  1. Press and hold the Enter button on the media center.
  2. While holding the Enter button down, press the Store button. Selections will appear on the media center display each time you press Store.
  3. When Video appears as the selection on the display, release the Store and Enter buttons.
  4. Use the Volume up and down buttons to scroll through the Video options.
  5. Stop scrolling at the proper selection:
  • For a component connection only, select:
  • -NTSC COMPONENT (in N. America)
  • -PAL COMPONENT (outside North America)
  • For a component connection and progressive scan, select NTSC PROGRESSIVE.
6. With the proper selection made, press Store to confirm the
selection and leave the Video options.
I hope that helps.
_______________________________________
Bose LifeStyle 38 Manual Download
Reset Bose LifeStyle 38 VChip Password
on May 02, 2010 | Bose Lifestyle 38 System
No sound Bose Lifestyle 38 III
I am quite sure that the indicator lights should be green. The blinking yellow likely indicates that there is no communication between the head and the audiomass. Verify that the connections are tight and then try powering off (unplugging) the system (both head and audiomass) for 30 seconds and then powering on again. That will often re-establish communications.
Aug 18, 2009 | Bose (321GS) System
Same problem LS 38< two years, error 802, unplug and erase umusic
Sounds like hard drive is failing, 802 and 801 is hard drive problem. i have same problem. only fixable by bose repair man... tryed to change hard drive myself, changed over, looks same as playing but no sound. hope this helps:) common problem with bose other than that i have had not other probs.
Jul 10, 2009 | Bose Lifestyle 48 System
Bose Lifestyle 48 System play's dvd in black & white only also connect to vs-2 video enhacer hello, my bose lifestyle 48 only plays DVD's in black and white. I can't find a setting or a reason why it...
Your s-video cable at the back of your media center is loose. This will cause black and white internal video and is known to fall out or just become loose from minor movement. (it's the nature of s-video cables) This should solve your problem. This is the s-video cable that connects to the VS2 and media center.
If this doesn't solve the problem (I'd be surprised), just reset it by unplugging the DC power cable at the side of the VS-2 for about 30+ seconds and plug it back in..
May 31, 2009 | Bose Lifestyle 48 System
Bose Lifestyle sound system shows "Failed 801"
your hard drive is about to fail or has failed.
If you can still play music from stored area and If you want to keep your songs thats stored on system, turn off at power point and take to bose auth repairer, they should be able to transfer songs across to new hard drive.
I have same problem, this is a common problem with bose.... not good for how much they are. Hard drive is left of cd tray, on its side.
hope this helps :)
Mar 29, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
No sound from Direct TV box
Unplug the Bose Media Center from the wall. Leave unplugged for approximately 30 minutes. Then plug the unit back in. Allow a few minutes for the Media center to initialize. Your sound should return as normal.
Jan 08, 2008 | Bose Lifestyle 38 System
Life style error codes 801 & 802
Hi, I had the same problem, they had to replace my harddrive and the dvd, lost all my music, 145 cds, just got it back, it now works fine,
good luck
jps
Dec 31, 2007 | Bose Lifestyle 38 DVD Home Entertainment...
When being in contact with BOSE support i got the message that "FAILED 802 Call Bose" refers to issues with the harddisk not being identified.
In my case I had to send the unit to BOSE support. I replaced the existing disk with an identical unformated one but some more actions are needed. The question is what .......
Nov 18, 2007 | Bose Lifestyle 48 System
DVD problem - now only plays in black and white
Check the video connections on the back of the Bose unit. I have a Lifestyle 38 and had an issue with video only playing in black & white. Turned out to be a loose connection.
Nov 10, 2007 | Bose 3 2 1 GSX System
Bose Lifestyle 38 System - white Theater System Logo
386 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
