Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Won't agitate on wash ?-on lf sign - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 240 Answers
If LF error code its long fill. control did not detect water entering/ no change at pressure sw. check pressure switch /hose. blockage in hose likely.
Posted on Mar 14, 2009
Model 11026955690. Why does screen indicate LP?
I am not familiar with any error code referencing "LP". Could you be seeing "LF"?
Below are the error codes listed for your washer:
  • "LF" (Long Fill) Inlet hoses are kinked or clogged or water valve screens are not clear. (Solution: Straighten inlet hoses or clear screens of any foreign material.)
  • "LD" (Long Drain) Drain hose is kinked or clogged. (Solution: Straighten or unclog hose.)
  • "FF" (Fill Failure) Problem with water level sensing system. (Solution: Call for service.)
  • "OL" (Open Lid) Lid Is open during drain or spin. (Solution: Close lid.)
  • "PF" (Power Failure) Power to washer went off during cycle. (Solution: Press any pad to clear the display. Restart the washer from the beginning of the cycle.)
Source: Kenmore 11026955690 Manual
Aug 25, 2015 | Kenmore Washing Machines
Whirlpool model la5558xs agitator won't turn during wash mode
Replace the agitator dogs. Here is the part to order.
There is a video on that parts page to show you how to replace them.
Dec 03, 2012 | Whirlpool 3.2 cu. ft. Plus Washer
Kenmore washing machine won't agitate?
You are referring to the "agitator dogs". Does the unit run during the wash cycle put the agitator does not move?
Nov 24, 2012 | Kenmore Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washing machine is making a clicking/ticking sound when it is agitating during wash cycle
This is a sign of strained agitator components that are about to be damaged or stripped. I recommend pulling the agitator and clutch. inspect each device for stripped components and uneven ware. replace the agitator and clutch if found to be faulty.
Check the transmission(gear box) for damage as well. fill with oil if needed.
May 27, 2009 | Washing Machines
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Kenmore electronic 90 series washer
easy easy you need agitator dogs thats right the official name of the part is agitator dogs! 5 dollar part can chat you through the fix
Mar 25, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
154 people viewed this question
Dan Webster
Dan Webster
Sal De
