Question about LG LS-L1210CL Mini Split Air Conditioner
My mini split does not run
Well a have a problem with my lasko minisplit, when turn on, unit does not run , a light flash comes intermitented, no compressor, no fan nothing is working, what do i need to do?
  • Anonymous Mar 28, 2009
    I have the same problem!, when I connect my miniplit it just star flahing the opertion light but nothing else hapens, no vent no compressor, what can i do?
  • 400 Answers
Check that you are on the correct mode setting. Open the remote and press the mode button (the one with about four little icons, star, teardrop, triangle and sun) until you get to the mode you require. If cooling required, select the star or crystal, if heating required select the sun (circle with little lines)
Posted on Mar 09, 2009
How to check MSG12HRN1W MINI SPLIT SYSTEM electronic board
If your mini split was installed to meet most building codes, an inside disconnect switch should have been installed. This switch breaks the power and signal from the outdoor unit to the indoor unit. It is not the same as the outside disconnect to the compressor (outdoor unit). If it was turned off, the inside unit would be dead. Look for a disconnect switch inside your room. By code is should be within 15 feet of the inside unit.
Nov 04, 2014 | Heating & Cooling
LMN096HVT
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | LG LMN096HVT WaMounted Mini Split Indoor...
Hello, I purchase an LG dual split minisplit air conditioner. It worked all summer long but now both wall units display a "CH 46" error and do not turn on. Any idea what the problem is and how...
A CH46 error indicates the low side sensor or suction line sensor is defective and not within acceptable parameters. It may be loose or off or simply bad.
Sep 12, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
I need a fan motor for my ge minisplit as0cd12db0 outdoor unit. Where can I get one?
Appliance Parts Pros 1-877-477-7278 or website appliancepartspros,com, Part# AP2053915 fan motor made by G.E. $119.82
Oct 17, 2009 | GE Quiet-Aire Ductless Mini Split System...
Ductless minisplit in old mobile home
ductless mini split units are a very good choice!  they are obviously quieter, more efficient and easier to maintain than window units. the downside is the initial expense of buying the unit, but this is paid back in eletric savings and peace of mind. Good luck Peyton
Mar 07, 2009 | Soleus KFR12GWD 12,000 BTU Heat & Cool...
York mini split unit has power but will not come on stand-by.
york split ac indor unit no working .timer light is on . how to stope timer control light ?
Jan 12, 2009 | Frigidaire FAA065M7A Air Conditioner
Soleus KFGHP-09-ID Mini Split
This is normal operation for these styles of minisplits. The thermostat is not in the remote but is located on the return air of the indoor coil, so the air needs to be flowing in order for the thermostat to measure the rooms temperature. Set your fan speed to auto and the fan will slow down when setpoint tempurature is met.
Phil Hodges,
Tech support Soleusair
May 18, 2008 | Soleus KFS18GW 18,000 BTU Heat & Cool 230V...
R22 LOST (SOMEONE STOLE PIPE),
be careful but dose in gas slowly until the frost line reaches the end of the evaporator
Mar 21, 2007 | GE Quiet-Aire Ductless Mini Split System...
LG LS-L1210CL Mini Split Air Conditioner Logo
566 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
