Question about Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor
I need to replace a switch for my trolling motor but I dont know what voltage it is. Ive tried looking on the trolling motor and could not find any nameplate info that would tell me, and I dont have the owner's manual for it either. I have two batteries for the trolling motor but do not know if they are hooked in series or parallel.
  • 257 Answers
Hi, If you picked the right header and it is a Maxxum 55 then it is a 12v motor. So you should hook up your batteries in parallel. This should Fixya!
Posted on Mar 06, 2009
Good battery , good battery in remote 70 lb thrust trolling motor - no go. ?
Hey Rob,, ??? ..Did you have the batteries CCA checked?? Cold Cranking Amps..?.. this is the only check to determine if your batteries are actually "good"...Next, take a volt meter and check the voltage at the trolling motor connection..if you have voltage at the plug, its time to move up to the head of the trolling motor...Since I do not know what brand if trolling motor we are working on.. these guys will take care of you from here...
home
Jul 09, 2017 | Boating
96 LUND TROLLING MOTOR PLUG WIRING 3 WIRES ON PLUG 2 WIRES ON TROLLING MOTOR CORRECT WAY TO HOOK UP
What is the voltage of the trolling motor (2 wire) (12V, 24V,36V?)you are trying to attach to the boat(3 wire). Please fill in more info and reply/repost to me. This is not a hard one!!
Thanks
May 26, 2017 | Boating
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
Ive recently bought a 1988 jaguar xjs 3.6 auto coupe and both electric windows dont work. ive noticed there are no fuses to change in its manual and that it has a reset button but i cannot locate it. can...
Amazing cars and fun too! It is not uncommon for these motors to fail. Sometimes if you smack the door just right or try to activate the window switch while closing the door. If it activates, replace the window motors. If you have a volt meter, you can remove the door panels and check to see if you are getting voltage to the motors while activating the switch. Let me know.
Oct 20, 2010 | 1985 Jaguar XJ6
We have boat that came with trolling motor, boat not used in 5 years what should we do to service the motor/minn kota 40at before we put in water we hooked to battery it spun and quit?? not sure what to...
My guess is the motor has leaked water into the lower motor assy (behind the prop). and needs to be cleaned up and the brushes replaced.
here's a schematic:
Edge 40
You can try this to check for water leakage:-
1) disconnect from power supply
2) remove the prop
3) you will see 2 bolt heads behind where the prop was. Remove ONLY ONE of them for now.
4) if you see the bolt (it's about 8" long) is covered in what looks to be blask, oily/watery or rusty condition then you know that you'll need to overhaul it.
5) if it IS the motor assy, remove the other bolt and disassemble everything noting their location.
6) I would recommend replacing the brushes Part# 188-052 and the seal kit 2883460.
Sep 23, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
Lcx26hd screen gets black when minnkota trolling motor is on has got good picture when off
Sounds like a simple voltage problem due to the current draw from the trolling motor. You will need to have a seperate isolated battery to run the trolling motor.
Sep 15, 2009 | Boating
Minn Kota Trolling Motor will not run
Hi!
For starters, here is a schematic:
Endura 30
Check to see if there is appropriate voltage getting to the switch (with an ohm meter).
You can (please do this carefully) disconnect the battery positive and negative as well as the motor red and motor black wires and connect the Batt positive to the motor red and the Batt negative to the motor black. If the motor runs, the switch is faulty. If it doesn't then I suspect the motor needs looking at.
Best of luck!
Mike
Feb 06, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor Logo
453 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
