Question about LG WM2077CW XL Front Load Stackable Washer with 7 Washing Programs
Start/pause switch works intermittently. How do I
LG model # WM2077CW:
Start/pause switch works intermittently. How do I remove panel to reach it?
I have found that the micro switch burns out on them and needs to be replaced. remove rear screws remove top cover , remove shield the unclip cables and front panel
Use a multi meter to test micro swicth on circuit board replace if faultsy
Posted on May 01, 2009
Start/pause button is not working on my LG washing machine. All other buttons are working fine?
Problem maybe that the START/PAUSE button has broken loose from the control panel. All the buttons are attached to control panel and "hinged" so when you press the button, the button presses a small button switch on the display control. You may have to order
the Control Panel.. Disassembly is required to inspect.
It would be least likely that the Display PCB is bad..
Aug 19, 2014 | LG WM1814CW Front Load Washer
When i started the machine, it went to start, then clicked and gave me a f dl error message. the door is now locked and will not even allow me to get clothes out. i have unplugged the machine several...
Unplug the unit, remove the lower access panel (front of the machine) reach up and find the small lock release tab and pull downward to release the lock manually. remove your clothing. This is usually do to a door switch failure. Replace the door switch. It may also be a wire coming loose or making intermittent contact. Hope this helps
Oct 22, 2010 | Whirlpool Washing Machines
LG WM2077CW small item trapped behind drum
you would need to remove bottom exit rubber pipe from drum and use a flash light to free coin or screw,hope this helps
May 27, 2009 | LG WM2077CW Laundry XL Front Load...
Maytag stackable washer top loader
try replacing entire lid switch assy, come ith new fuse!
Oct 31, 2008 | LG WM2077CW Laundry XL Front Load...
Whirlpool Duet model number GHW9100LW2-control lock button stuck on red, cant do anything else. Tried pushing the pause cancel button nothing......An ideas? Thanks!
Press the "End of Cycle Signal" button, the last button on the bottom right, for 5-10 seconds. That should resolve the problem.
Uppi
Sep 07, 2007 | LG WM2077CW Laundry XL Front Load...
LG WM2077CW XL Front Load Stackable Washer with 7 Washing Programs Logo
257 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
