Question about Delta BS100 Shopmaster 9 Inch Bench Top Band Saw
Delta shopmaster bs 100 band saw
I need to know what size blade this takes. this was given to me but my friend doesnt have the manual
  • 257 Answers
Hi, This Delta saw uses a 59 1/2 inch blade ( 1511mm).
Good Luck, this should Fixya!
Posted on Mar 06, 2009
How much is a delta shopmaster band saw model bs
It should only cost around 40-60 dollars.
Sep 03, 2014 | Saws
Delta shopmaster. . How do i instal blade guard on Delta shopmaster?
To adjust the blade guides , you have to loosen the lock nut ( it's normal on the upper part of the guide kit, outside part). Move the guide carrrier until both bearings are approximately 1/16" behind the gullets of the blade. Release the adjusting screws to set both bearing guides to within 1/32" of saw blade by turning the micro-adjusting knob. You can then lock the bearing guide in position once the correct adjustment is reached. This works on 14" band saw. This is an instruction from the manual.
Jun 13, 2014 | Saws
I need a manual for the shopmaster BS100. rachelsue@verizon.net
i need a manual for delta bs100 shopmaster 9 inch bench table band
Dec 17, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
What size guide blocks for band saw 28-185? Are they 5/16 x 5/16 or 1/4 x 1/4?? Thanks.
They are probably the 1/4 , most people make these things themselves out of nylon or some other material, I have seen brass and copper, plastic, anything to let the blade slide. Even saw one saw with round copper rods in the square hole guiding the blade, anything will work. Save the trouble of buying this stuff. Hope this helps.
Jan 17, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
My blade on my Delta BS100 Shopmaster 9 inch bench top band saw wanders. It is impossible for me to cut a straight line even with a fence. I have adjusted the blade guides several times as well as the...
Check and see if one of the guides is out of alignment or if the blade is worn. Either one can cause the problem since you already checked the tension and guides. If the guides are worn they won't hold the blade true.
Dec 30, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
Mar 31, 2009 | Delta 28 168 Bench Band Saw Blade 56 1/8...
Where can I purchase blades for the Delta BS100 bandsaw?
You have a couple options, you can buy direct from Delta by going to Dewaltservicenet.com and clicking on the Delta icon on the top or easier go to Ereplacementparts.com and down at the bottom of the site you will find accessories click on the saw blades and pick what you want. Let me know if you need more info.
Mar 20, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Delta BS100 Shopmaster 9 Inch Bench Top Band Saw Logo
732 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Delta Saw Expert? Answer questions, earn points and help others
