Question about ASUS NVIDIA nForce Chipset A7N266-VM (A7N266-VM W/L) Motherboard
No power at switch on no power seems to at PC
  • 167 Answers
Hi, my guess is power supply. did it work normal, before it failed? this is a possible solution, carification request. also for about 10.00 bucks you can get a power supply tester. there is other ways to check it also if you know what wires to jump- i will tell you, what wires to jump with a paper clip-look on the atx molex plug on the power supply-do you have a green wire? dell and other brands are proprietory and use different colors alot. and so you buy the parts from them...the board could also have a problem..
Posted on Mar 06, 2009
  • glenn hoffman
    glenn hoffman Mar 07, 2009
    do not do this unless there is a green wire,or you are sure of what you are doing..jump the green wire(ps-on) to any adjecent black wire(com) . if the fan on the power supply spins it is ok. then the problem lies in the mainboard or other hardware. post if you need help.ghoff1 hope this helps you.
When I turned my computer on most times the switch wouldn't start the computer I replaced the switch no power I'm thinking it's the power supply
CABEL8X1. NEED TO NO MOORE TO HELP.INFORMATION IS IMPORTENT.1 IS THERE FANS MOVING. 2 ANY LIGHTS ON THE MOTHERBOARD.
Apr 04, 2013 | Gateway GT4010 (RBGT4010) PC Desktop
I started having problems turning my pc on, seemed like the switch was going bad. It finally wouldn't come on at all. I took it to a pc repair shop, they told me the power supply, and motherboard were both...
Remove the 2 wires from the motherboard which connect the switch and start the PC by shorting the 2 pins with a screwdriver for 2 secs and see if it starts without failing. Cheers from Scott and plz vote
Jan 14, 2011 | Gateway 831GM PC Desktop
T-5010 Power supply issue
the voltage switch should be a small red switch, right below where the power cord plugs in. you will need a small screwdriver to switch it easily.
if you are getting no power at all, i would also check all the wiring connections on the motherboard from the ATX power switch. these are not that hard to dislodge and could also account for your problem.
hope this helps
Feb 16, 2010 | E-Machines T5010 PC Desktop
Power save mode
You have to have a wired mouse mouse to fix it. Purchase a cheap one, or borrow a friends. Reboot the computer and go to the power options to make the changes.
Feb 11, 2009 | HP Pavilion Media Center TV m7680n PC PC...
PC will not turn on
it seems your motherboard doest get powered or your on/off switch is not working.
please check the power supply if its fan is working ,if it is working please open your PC's cover and you can find the power switches on the motherboard. i want you to shortcut the power pins.
how you can find them ? you can see these pins at the corner of your motherboard . if you can find and shortcut the pins ,and if your power supply works ,then i think problem is your motherboard. you should replace it .
Nov 03, 2008 | Evesham Axis PC Desktop
No Power
please change your SMPS (Switch Mode Power Supply) it's not working properly
Oct 29, 2008 | Acer Aspire™ T180 PC Desktop
I have an all in one PC (Advent T200). over the last couple of days as I have switched in on the PC responds, the hard drive seem s to whirld then it just stops and thinks for a while and switches...
does the computer completely shut down ?
There is a known issue with the power supply in them. Not enough rated wattage for the system.
Robert
Aug 28, 2008 | Computers & Internet
PC won't start - Moved from Australia 240V 4 amps to US 110V 8 amps
well..you may need to change the input switch on the power supply try that first.
Mar 23, 2008 | Dell Dimension 8200 PC Desktop
Help on a compaq desktop pc
you seem to have a doggy Power supply unit that 's tripping or the power swith is faulty... it seems more like the PSU
Jan 07, 2008 | Compaq Presario 5000 PC Desktop
Shuttle will not start from power on button-
Hello Mitrabbit
Happy Holidays
well, is a problem with lines, that you must change, and welding the ground to the line should fix that in your particular case. but carefull not to weld much,the ground line.
good luck
Dec 03, 2007 | Shuttle XPC PC Desktop
ASUS NVIDIA nForce Chipset A7N266-VM (A7N266-VM W/L) Motherboard Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
