Question about Ricoh Aficio 1515F Plain Paper Laser Fax
Aficio 1515F, indicator error light
The first indicator light is on (Looks like an "L" on top of an upsidedown "L" and getting the message from time to time that a side cover is open but it is not. Faxes are not coming through... Thanks for any help you can provide. Richard
Thats' the general 'attention' light when basically anything goes wrong.
I've found some of these machines to be sensitive to the front/side cover switches...it may need adjusting, but if you make sure when you close the right side cover to press firmly at the top/ front of the panel (nearest you), as opposed to more towards the centre or back of the machine (which is the tendency) you may have more luck - that's where the interlock is....hopefully this helps
Posted on Mar 06, 2009
Making a black line on copies top to bottom right in the middle
maybe your scanning glass have a dirt! try to open the document feeder and clean it! or it possible that the problem was coming from the cartridge.. =)
May 17, 2010 | Ricoh Aficio 1515F Plain Paper Laser Fax
How to change time setting
Press the USER TOOLS button, set from the KEY OP menu.
Nov 04, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
When machine was moved from one line to another it now gives a "handset" error message in the window constantly after you try to dial in a number and use the fax machine; the communications tech. says it...
Your fax tech is correct. There is another device on your fax line such as a credit card machine, a postage meter, computer, etc.
You should have a dedicted analog phone line for your fax machine.
Oct 12, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Need to Double Side
press the "duplex" button on the operation panel
Jul 23, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh ft4215 problem
do you get an error code on the display, or does it flash open door/out of toner/out of paper/paper jam or what ?
mikey
Mar 13, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh aficio error message 06-06 page not received
its a fax error that states there is a line problem, problem is probably static in the phone line
Feb 18, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh aficio 1515f printing dark line down left side
If the print can be rubbed off then this suggests the fuser unit is not working correctly. It could be that the thermistor is covered with toner and making the machine think the fuser is hot enough when it's not.
The black line could also be caused by the fuser if one of the pick off fingers is coated with toner or has worn into the Teflon of the roller.
Does the machine show the lines when you print a page from memory - such as a counter or config page? If not, this would suggest the optical path is dirty. Try cleaning the glass and look at the mirrors inside the scanner to see if they are dirty/dusty.
We removed the waste toner bottle and it won't reset the error message
You will need to vacuum all the toner out as in the machine there is a sensor that looks through the waste tank and checks that it is clear. You can also wash the tank out then install it and you will not have the problem.
Thanks J
Jan 25, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh 1515f
This model can be used as a printer and a scanner , but you need to add a print scan controller wich you can obtain at any ricoh otlet .
Pierre
Sep 11, 2007 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh Aficio 1515F Plain Paper Laser Fax Logo
127 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
