Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
I have a new Samsung RFG297AA fridge and I am noticing a little frost on the outside of the pull out drawer in the freezer. What do I need to do?
  • 163 Answers
This could be that your gaket may be sucking in air.check gasket dollar bill trick.put dollar half way in freezer and pull it out.if it pulls out easy your gasket isnt sealing.be sure to go all around the freezer gasket with the bill.
Posted on Mar 06, 2009
  • Eileen S.
    Eileen S. Jul 23, 2012
    I have the same problem on my almost 2 yr. old Samsung RFG29ACRS French door bottom freezer fridge. The gasket leaks around the bottom pull out drawer about once a month and makes a huge mess with frost fuzz and always just on the right hand side. If I pull both the drawers open and fiddle around wiggling them off and back on the track most times it fixes it, but it is getting worse and very annoying. I called Samsung a year ago when it first started happening but they didn't seem to know of anyone else with this issue. Think it is time to call them again....anyone else with this problem or better yet a solution!? Thanks
Samsung RL38SCSW Fridge Freezer not Cooling
Sounds like an air leak around a door seal or the ice maker chute door is open causing frost buildup on evaporator and everything inside the freezer. You also may have a defrost drain line blockage
APPLIANCE 911
Jan 07, 2016 | Samsung RL38SCSW (113 cu ft
Frig wont cool fan not running freezer working
fan is not working thus u have very little cold air circulating into the fridge. check the fan with a multi meter for continuity? it may be out? When u say freezer working? is there an ice build up ? if so u may have a bad defrost terminator or defrost timer, which in turn blocks the fan from working due to ice build up?
Aug 14, 2014 | Samsung RFG297AA (285 cu ft) Bottom...
Frost in Freezer of BRAND NEW LG FRench Door Fridge!
After converting C to F, I reckon your freezer should be set a bit lower than -2 degrees for five star food storage. I think -15 F should equate to the ideal temperature of about -25 C for five star food storage.
Whatever moisture enters the freezer will become frost. I have not yet seen a freezer that is entirely frost-free and I have no way of knowing whether the amount of frost in your freezer is excessive.
Every time the door is opened, every time somebody exhales while the door is opened and every time unfrozen or barely-frozen food is added there will be moisture and therefore frost...
It is a good idea to use a separate thermometer to check/verify the internal temperatures.
A new fridge or freezer can take a few days to settle and no decisions should be taken before it has been given a fair trial. One point to be aware of is a fridge or freezer that is properly stored and then transported vertically can be switched on as soon as it is delivered but if it has been laid down or severely tilted it should be stood for several hours before switching on. Ignoring this could be detrimental to the performance and/or the life span.
Another important point is the appliance should be adjusted so it is as close to plumb or spirit-level vertical as possible to ensure long life and reliable operation.
Mar 01, 2017 | LG Refrigerators
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Oct 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
My freezer is frosting...there is snow all over
In my case with constant snow and frost build-up in my bottom drawer GE freezer, it was because the drawer never properly closed. As one user noted, "there is no adjustment." However, there are "catches" at the rear of the drawer glides and in my case one needed adjustment because it was preventing the drawer from remaining closed tightly. SEE PHOTOS. The photos show many items removed, but to make this repair, you only need a butter knife to pop out the black plastic catch mechanisms at the back end of the drawer glides, and only if you can see that the spring is not properly positioned. SEE PHOTOS
May 09, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
869 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
