Question about Dell Inspiron 1501 Notebook
Link to connect to wireless network does not work
When I scroll over the bars where the internet is connected it says that there are wireless networks available, I also just installed my new router, and when I click on the link to connect to a wireless network it does not do anything. It worked before and now suddenly nothing happens. Please help!
  • amberrocha Mar 06, 2009
    Thanks. This was happening before I bought the router though. I used to always be able to connect to a wireless network. Now it says they are available but when I click the link to see which networks are available nothing happens. When I got to my Network & Sharing center it shows my router and also says there are wireless networks available but when I click to see them the same thing happens. The link to see the networks just doesn't work?
  • 3 Answers
Make sure that the router is broadcasting your network (This is the SSID). If it is you should see the name of your network (make sure you change the name from the factory default). If not you will have to log onto your router (http://192.196.0.# number is specific to your brand of router. Should be in manual.).
When you log in under admin you can go to wireless tab and look for SSID broadcast. Make sure it is set to yes. If you have a power setting, make sure it is set to 100%
If you still cant connect you will have to run the network wizard that comes with your router again. Make sure to write your network key down (some routers are case sensitive so be sure to take that into account).
If that doesn't work, check the security levels, as it might be set to a higher level that does not accept new connections.
I hope this helps, if you have any other questions just let me know.
:) Lequarius
Posted on Mar 06, 2009
    Problem Solver:
  • 17 Answers
Try uninstalling your wireless device on your PC. Then reboot. It should automatically reinstall your wireless card after the reboot.
If you need help uninstalling it let me know.
Posted on Mar 09, 2009
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
Tip
How do I Connect my iPod Touch to a Netgear WNR2000 Router
<p>Netgear WNR2000, a wireless-N router, you can connect to the Internet without the hassle of cables. IPod touch supports Wi-Fi (wireless) connections. If you're within range of the router, you can connect to the wireless network. Once connected, enjoy a fast transfer speeds that allow you to quickly scroll pages and run the programs enabled network. <br /> <p><br /> <p>1. Connect the iPod Touch. Tap Settings on the Home screen settings of media player to start. <br /> <p><br /> <p>2. Scroll through the settings when you come to "Wi-Fi, tap to activate the feature. IPod touch detects networks in range. <br /> <p><br /> <p>3. Select the Netgear WNR2000 Wi-Fi network can include the name has been set, so it helps to know the name. If a secure network, enter the password. If you do not know the password, your iPod Touch cannot connect to the network. Once selected, your iPod automatically connect to the network. The Wi-Fi icon in the status bar at the top. <br /> <p><br /> <p>4. Select "ON" next "Ask to Join" if you want your iPod touch to ask you to connect to wireless networks within range. <br />
on Aug 05, 2011 | Apple iPod touch
My desktop an Acer Aspire Z5600 will not connect to the internet, my internet provider Hughes net has said that their modem is working properly. I have run trouble shooting on my computer and get a me
With a wireless connection, your PC can connect wirelessly to a network printer. In addition, you can set up your PC in a location where no phone line or cable connection exists. Outfitting your desktop to a wireless Internet connection is very easy. Just follow these simple steps and you'll be surfing the net wirelessly in a matter of minutes.
Find out if wireless Internet reception exists where your computer is located. If you're located very close to a W-iFi hotspot, like a coffee shop, you may be able to use this network to get wireless Internet for desktop PCs. Also, some apartment complexes and college dorms have free wireless Internet. Your neighbors may have wireless Internet too, which you can ask them if you can use. Buy a wireless network adapter for your desktop. You can obtain an adapter from most electronic stores. Be sure to get a wireless adapter with the proper strength, which depends on how far you are from the wireless hotspot. The easiest adapters to install are those that just plug into an available USB port. Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter. The usual procedure is to plug the wireless adapter into an available USB port. Windows will install the appropriate driver. After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars). A list of available connections will appear. Select the desired connection. If you are prompted for a password, enter the appropriate password. Click "Connect." You are subsequently connected to a wireless network. Launch your browser and enjoy surfing the Internet wirelessly. If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel." Then select "Network and Internet" and "Network and Sharing Center." Click "Change adapter settings" in the left pane. Double-click the icon of the appropriate wireless connection. The Wireless Network Connection status window appears. Click the "Wireless Properties" button. Select the "Security" tab and select an encryption type from the drop-down selection. Enter a password in the Network security key field. Make sure that the password matches the router settings. Press "OK" when done. Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area. You can buy these online, or at electronic stores. You'll need to set up your router using the accompanying instructions and your own Internet service provider. This is best in a home with multiple computers.
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled, If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake
Hope this helps.
Dec 21, 2012 | Computers & Internet
Connects through home wireless link but cannot
click control panel. In classical preview selecr - network connections. then from th left bar select "set up a home or small office network. follow the procedure, make your option and then it should be ok.
Oct 24, 2009 | Computers & Internet
Internet explorer does not open
If the internet connection is working but IE doesn't get to a page this generally has to do with either your DNS settings or your IE settings regarding the connection.
Please try this then reply back with the results:
open start menu, then RUN box(XP) or click into the searchbar(Vista)
Type cmd then hit enter, once the command window opens type IPCONFIG /ALL
a fair bit of info will scroll by and you will have to scroll the page up to find it but report back with your IP address, subnet mask, gateway and DNS server addresses and we can continue from there
Chris
May 11, 2009 | Computers & Internet
When i select my Linksys WiFi connection on my Iphone I still has the "E" edge symbol on my Status bar even though wifi is selected.
You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
Do you have problems connecting to any other wireless network with your iPhone?
Have you tried using the forget this network option on your iPhone for your wireless network followed by trying to connect to the network again, and/or using the reset network settings option on your iPhone which erases all previously saved wi-fi connections that you have successfully connected to with your iPhone?
Let me know....
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 22, 2009 | Apple iPhone 3G
Wireless connection, but no internet
Verified that the Internet connection is working good
- Now if your connected to the wireless network but unable to access a website try this:
- Open the control panel
- Open the network connection
- Right click on wireless networks (Choose properties)
- Choose Internet protocol then click properties
- Assign DNS Server address (Preferred DNS: 4.2.2.2, Alternate DNS: 4.2.2.3)
- Leave the DCHP as obtain IP address
Mar 04, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Connection using DSL-2640T
Try diagnose and repaire the connection if that does not work Reset your modem it should go back to default manufacture setup.Then turn modem off and connect any computer or laptop to the modem with ethernet wire turn the modem on go back to your computer that you are connected to modem with wire go to network connections and disable the wireless Network connection and enable local area connection once you see you have connected and have internet working go to start menu you can do this on the start search bar with vista or run with any other windows version type cmd and press enter, it should bring a DOS command menu and then type in ipconfig and enter scroll up and down to where you see default gateway type that ip address to your internet browser it should take you to login screen username should be administrator password admin setup your WEB key make the wireless access available DO NOT FORGET to write the web key down, give a name to the connection and change the default password from admin to something you can remember. save the settings and turn that off keep the laptop on. Then unplug the ethernet cable and switch the network connectiion again enable wireless disable local area also you need to scan the available wireless internet and pick the one you just named use the webkey to access and save when the connection in made.
Feb 18, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
D-Link 1310
If unsure of your network key try to reconfigure your wireless network again.
Access the configuration page of your router. type on the address bar 192.168.0.1
On login type Admin leave password blank. if you set up a >password or the login page use that one.
>Once inside the Dlink Page
>Go to setup and on the left side click wireless setting.
>If given the option to click on manaul wireless connection setup click on it.
>Once you have the wireles window
>try to change the network name and scroll down
>Under security choose WPA security (enhanced)
>Scroll down and under the Passphrase type in your new network passwork or security key and confirmed it.
>Click on Save Settings
>If it asked your to reboot then reboot if not its ok
>Using your laptop click start and go to "connect to" and click on your wireless network and connect to it and along the way it will prompt you to enter your network key or password. This would be the same as your passphrase or pre-share key type in your network key.
> Once connected to your wireless network, Open an Internet browser to connect to the Internet.
Jan 28, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I cannot connect to the internet using wifi
1. Go to START
2. select MY COMPUTER
3. Once in the new window, click MY NETWORK PLACES under the "OTHER PLACES" section
4. select the VIEW NETWORK CONNECTIONS link under the NETWORK TASKS section
5. RIGHT CLICK on your wireless network connection and choose PROPERTIES
6. click the WIRELESS NETWORKS tab.
7. make sure the "USER WINDOWS TO CONFIGURE MY WIRELESS NETWORK SETTINGS" box is checked
8. Click OK and close the window
9. RIGHT CLICK on your wireless network connection (the name of it) and choose REPAIR
10. if windows detects the wireless connection, you should see a bubble near the task bar
11. in order to begin using the wireless connection, open your web browser then enter your username and password (if required)
Dec 01, 2008 | Computers & Internet
Dell Inspiron 1501 Notebook Logo
184 people viewed this question
Alun Cox
