Cannot get paper to feed at all. There is no jam every thing seems to be clear. Printer is not even a year old
    Scholar:
  • 149 Answers
Check the pick-up rollers on the printer, they may need a cleaning. If they are moving, then they may need maintenance. You can find a liquid that will revatilize the rollers.
If they are not rolling, then it may be a hardware issue where the rollers are not being actuated. Good luck
Posted on Mar 06, 2009
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Can not print from HL-2040 printer
Discribe your problem exactly. Paper not feed or paper jam, or printer not responding, or something else.
Feb 08, 2011 | HP LaserJet 1000 Printer
Scanner not feeding on lexmark x7170. paper feeds halfway in them reports error/clear paper jam in scanner document feeder.
I have the same all-in-one printer and have just recently, the unit is a few years old, started having the same problem. I found that that if I make double sure the pages are evenly stacked and very carefully placed in the feeder tray, the problem is less common. It doesn't work everytime but ar least I get my faxes through on the first attempt 75% of the time.
Nov 10, 2010 | Lexmark X7170 All-In-One InkJet Printer
I seem to have a paper jam on the right side of the paper feed - I have tried to clear any objects but it seems fine - it just creases the paper slightly and it will not feed through and print.
Yeppers, there is a SMALL object in there. If you have an air can, that is the best option to clear even things we do NOT want to clean up after they come out, but it is needed. If that does not work, you can use a combo of Q-tip and rubbing alcohol, or vodka and stick it in there and wipe hard to see if you can clear anything. Also, you can tip the printer towards you, holding tight and lightly whack the back to help dislodge the item. Also, you can try a piece of poster board paper to jam in there to get the piece out... PLEASE let me know if these do not work, we can try a few more things... Thanks for letting me assist you today, is is my pleasure.... Guy
Oct 15, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Paper jams at every feed - even after I clear the jam...
Make sure all paper has been removed from the paper path.
Even a small scrap will cause a jam.
The other thing you may want to do is clean the paper rollers with alcohol.
This cleans any paper dust that has gathered on the rollers, and allows better paper movement.
Sep 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Constant jamming recently
Could be 2 things..
First Check close and make sure there are not small bits of paper in the feeding arms rollers etc.. any place paper passes make 100% sure. Second adjust the tension from the feeding arm and make sure the paper path to the printer is clear.
You can also hit it with a few shots of Dustoff
Jun 17, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
I can only print by manually feeding in each page -HP 4MV Printer
Good old 4MV.
paper jam is just the way the printer i stelling you "something" wrong with paper feed".
you need to locate a "4MV repair kit" , they are not cheap. but, if you wan to keep the printer, it is worth it.
http://www.fixyourownprinter.com/kits/hp/K78 cost of the ket is $50
includes Instruction CD rollers, and other repairable parts.
Dec 15, 2008 | HP LaserJet 4mv Printer
HP 2840 printer paper jam
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
Sep 08, 2008 | Office Equipment & Supplies
Machine shows "Paper Jam" error
There is a paper senser present in the paper lifting area. That part of your printer is not working properly. Replace that part and then try
Sep 20, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
79 people viewed this question
jasbo
jasbo
