Coppying speed is slow
I am using d102 motherboard,p4 processor,(3.06,3.07 processing speed) 2 gb ram and 250 G.B harddisk ............. thoug my sys configuration is more than enough coppying speed is low.the maximum seed is 10 mb persec while in others is 30 mb persec (movies) in my sys any how coppying speed does no go beyond 10 mbps......... I AM GETTING THIS  PROBLEM IN BOTH VISTA AND XP........... I CHANGED THE OS  ALSO...........
  • 408 Answers
In vista you need to change the remote differential compression.  Can be found in control panel?programs?windows settings I believe.  Turn it off.  As far as XP, sounds like a problem with the hard drive or memory.  I know of this issue in vista, but never ran into it with XP.
Posted on Mar 06, 2009
My pc is very low.I need fix
Slow PC does not mean it has problem only with motherboard. Speed of the PC also depend on the following factors :
  1. Processor
  2. RAM
  3. Virtual memory
  4. Operatin system
  5. Video graphics card
To fix the problem you should first check which type of processor is used in you PC. Is it pentium4, Dual core, Core 2 duo or core 2 quad ? Core 2 quad is much faster if used with 4 GB RAM. RAM is also the cause to slow the PC. If you are using less RAM automatically your PC will be slow. So use RAM higher i.e 2 GB or more.
Virtual memory does not have much impact on speed but it is also a factor to slow down the PC. But if you can correct any of the three parts then no need to check virtual memory.
If you are using operating system like Vista then computer may be slow. Instead use XP professional, Windows 7.
If your PC doesn't have graphics card then it will be slow while playing games, watching videos. So if you are a game lover then change your graphics card with higher value such as 2 GB or more.
If you will fix these problems then you can speed up your PC
May 29, 2011 | Computers & Internet
Can intel d102 motherboard have 667 fsb ram
I am not able to find a 533 MHz 1GB DDR2 RAM.. Has anyone used a 667MHz 1GB DDR2 on this board D102GGC2 ?
Dec 25, 2009 | Intel D102GGC2 Motherboard
I have elite mother board P4 M800 PRO M2 socket 775...the problem is always hang and to slow..i reformat 3 times but the problem same plz help me i need assistance..
This are things that need to consider in a computer speed performance:
1. Amount of ram memory(If you have only small amount of memory then your computer performance is poor.)
2. Speed of your processor(You should need at least a 1Ghz processor speed or more).
I suggest you increase your ram memory so that your computer will perform faster.
Dec 16, 2009 | EliteGroup P4M800PRO-M Motherboard
Swaping hdd 845 motherboard to 915 motherboard
its always safe to have data backed up
u can swap the HDD
but bootup with the Win2K CD in the Drive and after the files are loaded at the first screen select install then after it detects the OS select R (Repair) and this will reinstall the operating system files and then you can use the system as before though u may have to install the device drivers and motherboard drivers
for any other clarifications u can place a comment in the same question or u can mail me at
Jul 30, 2009 | Intel Pentium 4, 3.0 GHz 530...
I can't use this as a bootable device with Windows XP.
Not every PC is capable of booting from a USB flash drive. For the most part, computers manufactured within the last two years are generally able to boot from a flash drive. Older systems may require a BIOS update, or might not be able to boot from a flash drive at all.
Drive must be formatted with FAT file system.
For your systen you need an internal Hard drive.
Rakesh Kumar
Apr 08, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My cpu usage is more ,transfer rate i.e coppying spee is low
hi,i think this is most likely just your os .files on harddrive corrupt.reinstall windows!
Mar 06, 2009 | Computers & Internet
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from
Oct 17, 2008 | Intel D845GLLY Motherboard
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
