Question about Rolex Datejust SS
How to adjust day date on older rolex perpetual day date watch
How can i adjust day and date on an older rolex perpetual day date watch
  • 2,334 Answers
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Mar 07, 2009
My wife's Rolex Oyster Perpetual watch is running very slow. It was cleaned approx 7 years ago and seemed to run properly. I phoned the NY service center which quoted a $600 basic cleaning fee which seems...
Hi , I am sorry to say that a rolex requires servicing on a regular basis . Every 3 - 5 years would be advised . If you consider that your watch is a delicate machine that may be working 24 hours a day for years then its not unreasonable that it needs servicing. Over time the fine oils dry and degrade , they need replacing , and parts can become damaged .
As to cost , this is a skilled job . To service a rolex in the correct way requires not only skill ,but the correct tooling and equipment . Also the materials used must be genuine rolex , this is costly . Your accredited service centre will then provide a 2 year guarantee .
All in all the price of $600.00 reflects the labour of a skilled man and his investment in gaining rolex status .
There will be cheaper alternatives but beware as they will probably not be rolex trained and wont be using original materials .
Aug 01, 2013 | Rolex Oyster Perpetual Day-Date Watch...
The date and day have stopped working on my replica rolex daydate i have adjusted the pin several times but it is still not moving?
Your calendar wheel is damaged. Unfortunately, it is illegal to own or work on a Rolex replica / fake Rolex as it is a trademark violation. I would suggest purchasing a genuine Rolex as a replacement, as there are generally no identifiable movements, and therefore no identifiable replacement parts for the movement in your timepiece.
Be aware, however, that all automatic and mechanical watches, such as Rolex, must be services regularly, every 3-5 years, for them to last and work properly. Thanks for the rating!
Dec 16, 2012 | Rolex Oyster Perpetual DayDate 118239BKSP...
Hello please help, I wish to know what year Rolex Oyster Perpetual Lady Date model 6519 was Manufactured. Thank you in advance.
This model Rolex has been manufactured over multiple years, and it is not possible to date your watch based purely on is model number. However, it is possible to date most Rolexes based on their serial numbers, which can be found stamped between the lower lugs (i.e., the lugs below 6:00 on the watch dial). You will need to remove the band from these lugs to read the serial number.
Dating the watch case of a Rolex does not necessarily date the entire watch. It is possible that a movement from another watch was placed into a watch case that is younger or older than the the movement. Like Rolex watch cases, Rolex movements can also be dated by their serial numbers, if this is a concern you have about this particular watch.
This jeweler has put together a nice summary of when Rolex watch models were introduced and which serial numbers are associated with specific years of manufacture. Once you have found your serial number, this should help you date your watch. I have no connection (financial or otherwise) with this web site, but I found the information useful and presented in an easy to understand way.
http://www.bgrayjewelers.com/rolex_information.htm
Jun 03, 2011 | Watches
I got a president day date rolex, sometime the date jump twice in 1 day
Reset the time, day and date manually from scratch. Check for another 24 hours. If the problem persists that means there is interference between day and date wheels and in this case you will need watchmakers help, as to correct such a fault the watch needs to be disassembled almost completely.
Feb 24, 2011 | Rolex Oyster Perpetual DayDate 18kt Yellow...
Oyster Perpetual Day Date keeps stopping
That does sound like a peculiar problem. Without looking at it it's difficult to say. It possible the date change - stopping situation is co-incidental. All mechanical watches, particularly high quality one such as this should be serviced every two to three years to ensure optimal performance and preserve their value. I recommend you take it to a qualified repairer. Good luck.
Jul 28, 2009 | Watches
How do i wind and set my Rolex Oyster Perpetual watch
After all settings being done, always screw the crown back down as it protects the watch from water and moisture.
Apr 04, 2009 | Watches
I need an owner's manual for a Rolex Oyster Perpetual Day-Date. Any idea where I can locate one?
Mar 31, 2009 | Rolex Day-Date President 118238 Wristwatch
Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
Dec 12, 2008 | Rolex Datejust SS
Rolex Datejust SS Logo
1,007 people viewed this question
Top Rolex Watches Experts
Samyfam
Samyfam
Are you a Rolex Watch Expert? Answer questions, earn points and help others
