Question about KitchenAid KUDR24SE Built-in Dishwasher
How do I reset the electronics on my KitchenAid KUDR24SE dishwasher
  • 906 Answers
Good day,
hope this link below will solve your problem.
kitchen
Posted on Aug 04, 2010
KUDR24se broken handle door locked - how to open for repair
Hello, Thank You for using FixYa. I will be helping you today.Just open the door and remove the screws around the top panel and pull the control off starting at the top. It can be hard to get off at times but thats how it comes off.
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | KitchenAid Dishwashers
Dishwasher clean light will not stop flashing preventing further input and dishwashing
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Dec 14, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
Control panel unresponsive
open up the inner door shell after powering down the unit from the power source,wiggle and remove and replace all ribbon cable connections on the electronic control panels and any other connections you can see,moisture corrodes these connections after years and removing and re-installing these will sometimes wipe off any corrosion for a better connection to the machine the screws are on the inside of the door to access the control panel
Jun 19, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
Dishwasher stopped mid-cycle. No power lights etc. Checked fuse box etc. no luck. Any ideas what could have caused this?
There is a thermal fuse in the control panel that must be replaced.
It is on the right hand side and has a black and a white wire going to it.
Apr 23, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
KUDR24SE hinge springs have broken, how do I get in to replace them?
You have to remove the screws holding it to the counter top and slide the dishwasher out about 1 foot and you'll be able to reach the springs at the bottom on each side.
Mar 07, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
My DW won't run. the lights come on but it won't run.
You are not giving any kind of useful information, in which a tech can help you.
Please respond with a make and model number and I will look for your comment and respond ASAP.
Nov 08, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
KitchenAid KUDR24SE dishwasher doesn't drain.
check the drain tube at the disposer
Jul 02, 2009 | Dishwashers
Leaks during wash and rince cycles
hi, Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , open the door after few min check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards!
Jun 25, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
Kitchenaid dishwasher KUDR24SE...cannot open door
did anyone have a solution? i have the same problem.
May 16, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
Dishwashers Logo
354 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
