Question about Refrigerators
How do you get the defrost overflow tray out from the bottom of the fridge to clean it? The water filter is in the way. Do you have to unbolt that and get it out of the way?
  • 163 Answers
You really shouldnt need to remove tray.
Posted on Mar 06, 2009
My 1 year old Danby DBC514BLS tray in back is overflowing on the floor/hardwood. What could be wrong?
Its probably the defrost tray. Most fridges / freezers allow the defrosted water to run into a pan at the back of the unit where it evaporates away. If there is too much water, the tray cant handle it and it overflows.
Nov 20, 2016 | Danby Refrigerators
Condensation water build up inside refrigerator
The tray underneath your fridge is probably clogged, and overflowing. There is an evap tray underneath, and if it does not get adequate airflow, it will overflow, and leak out.
Clean the bottom front vents, and underneath the fridge to ensure adequate airflow.
Mar 31, 2014 | Sub-Zero Refrigerators
My Liebheer stand alone fridge is filling up with water in the bottom of the fridge.
This is due to the defrost water condesing and overflowing out from the drain tank.
So keep the fridge in a normal temperature and make sure that the tank is empty. Also check if this is an overflow or that the drain hose is leaking from the top of the evaporator collecction tray. If so check out the leak point and patch up.
Other wise if the fridge is working fine all what is needed to check out using a good inspectiion lamp, check the tilt of the fridge and set using a water level.
Jul 25, 2011 | Liebherr Refrigerators
Water is dripping from the bottom of the fridge (slow drip). How do I fix it. I have a Maytag French Door stainless steel fridge (4-year-old) with freezer on the bottom.
There should be a drip tray catching the defrost water... it may be overfull... Try to remove it and empty it. The tray is actually supposed to have a heat evaporator to dry up the water before it overflows. Your may be fuller due to excessive frost also... from hot temperatures outside or opening the fridge too often or for too long... good luck!
Jul 24, 2011 | Freezers
My fridge model CTF2123AR leaks water under bottom pull drawer. this pools water on the floor
Water found under the tray is due to excess defrost specially when the fridge is set to a lower temperature due to heavy frosting.
So during defrosting the excess water flows into the tray and overflows out which incidently has flooded on the floor.
What could be done is to drain off the tank, fully defrost the fridge by shutting down for few hours and then setting the fridge/freezer to a normal temperature.
Jul 13, 2011 | Magic Chef Refrigerators
Finding water at bottom of fridge
Most probably the water can be the overflow from the drain tank of the fridge to which the auto defrost condensation flows. Also if there is any leak onthe tubing from the evaporator tray this can happen.
So remove fridge forward and check,
Sep 22, 2010 | KitchenAid Refrigerators
How do I remove the water tray
The evap water tray is beneath the water filter and behind it. To remove the tray I loosened the water lines, unbolted the filter bkt. and removed the cross brace from the bottom front of the refridgerator after first putting blocks under the sides of the fridge and the coil bkts.
Jan 07, 2010 | Whirlpool Refrigerators
Freezer moisture overflowing into refrigerator
your drain is clogged, defrost the freezer and locate the drain either on the back or in the bottom of the fridge and clean it out. the water is coming from when the fridge goes into defrost
Sep 24, 2009 | Refrigerators
My hotpoint ffa74 fridge freezer drainage hole in fridge compartment never drains away the water. have emptied and defrosted but made no difference
Defrost the fridge. I recommend at least 24 hour period, it's normally quicker. After it has defrosted empty the tray at the back by simply unscrewing the tray and removing the little black rubber tube. To test that it has totally defrosted pour coke down the drain inside the fridge with the tray back in, this should filter into the tray. Clean the tray again and insert black rubber tube and tighten screws again, job done.
I had the same problem but it was all sorted within 16 hours as it defrosts quickly.
May 02, 2008 | Refrigerators
Refrigerator has water leak
Had the same problem with mine. Got a technician to have a look. Inside the fridge at the back there's an overflow tray. CHeck if this is not blocked. Clear it by putting a tray behind your fridge under the overlfow pipe and pour hot water through the overflow tray inside the fridge. Sometimes food gets stuck in there and nobody thinks to clear this out. Mine was easily unblocked and now its stopped leaking.
Apr 14, 2008 | Refrigerators
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
