Question about LG DR-4912 DVD Recorder
Lg dr4912 where can i purchase a new laser for lg dr4912 dvd recorder?
Fitted a new drive in but it wont play normal dvds.
it recognises +- discs and formats them as it should
just need to work out how to make it play normal dvds.
dont want to pay for advise thanks
Posted on Mar 07, 2009
LG RH265 does not read DVDs
Purchase a DVD cleaning kit and follow the instructions, this will remove any dirt from the laser pickup lens, and hopefully get it up and running. If this fails, the only other option is have the whole laser assembly replaced, "expensive" or replace the entire unit.
Mar 06, 2012 | LG RH1999H DVD Recorder/HDD Recorder
I have an DR275 LG DVD recorder. For some reason it stopped playing DVD discs. But it will play anything else you put in it I have cleaned the heads switch it of by the power as well. What could...
The laser mechanism has a number of optical components, not just the lens. There also additional fixed lenses and mirrors inside the laser unit which are very difficult to access. If sufficient dirt builds up on these components then the dvd laser may not work properly. Unfortunately it is very difficult (or even impossible) to clean these parts.
Another possible fault is that the CD laser is usually separate to the DVD laser and the DVD laser is no longer working properly, while the CD laser is still OK. In this case, the unit is definately not repairable without replacing the whole laser unit (not a readily available item and not likely to be cheap).
If the unit is out of warranty, your cheapest option is to buy a new DVD recorder.
Jun 16, 2011 | LG DR275 Recorder
LG RH278 HDD/DVD Recorder
I have an LG RH278 HDD/DVD Recorder, which was suffering from the problem that it could not play any bought DVD movies, which were previously working fine in that same player. It would however play svcd and DVD+R/-R movie discs.
The solution was to replace the laser tray. I found a new LG DVD BD lens LPC-815 laser tray here: http://www.laser-xh.com/en/?act=showproduct&proid=1147
I bought two for $5.50 each. Shipping was $32 (DHL), all together $45.10 (PayPal fees included). Delivery was fast and accurate within 3 working days (China - Sweden).
Feb 03, 2009 | LG DR787T DVD Recorder
Dvd drive cannot read cds and vcds but can read dvds only
I had the inverse problem on my unit - 7 months after I bought it brand new it wouldn't read DVD's, but would read CD's no problem -- I bought a replacement loader from LG, swopped them out myself and now works 100%.
Turned out the laser for reading DVD's had gone - they use different lasers or wavelengths or something... :)
Jan 09, 2009 | LG RH1999H DVD Recorder/HDD Recorder
LG DR4912 - Optical drive motor bouncing of the end stop.
Mine was doing the same.last night i opened up the machine & took out the cd drive and opened it up.I cleaned the laser with a cotton swab and manually pushed the laser back to the front of the unit as far as it could slide on the 2 little posts it slides along.
Dec 30, 2008 | LG DR-4912 DVD Recorder
WILL NOT READ SOME BOUGHT MOVIE DISCS
one of the solutions before spending $$ is, you need to open the unit remove the dvd loader,CAREFULL OF PLUGS AND RIBBON CABLES!!! open the dvd loader, clean the laser GENTLY WITH A CLEAN COTTON TIP, and re assemble. if that doesnt fix the units issue,the second option is you will need to replace the dvd loader, part number is found on white or yellow sticker. hope this helps.
Dec 20, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Disk recording and playback stopped working
Generally this means that there is either an internal issue going on, or that the laser has become dirty or has defected. Try bying a simple DVD cleaner disk and running that through a few times. If that does not work the product may be defective -- in which case I hope that you still have a warranty -- and if you do return the product promptly for a new one.
Michael Lazar
http://www.AudioholicBlog.com/
Oct 03, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Lg dr4912 dvd recorder
I think you can with that line of LG DVD player. Try it to confirm it. That will be the real test
May 28, 2008 | Televison & Video
LG 4912 using with a new digital TV
in order to solve the complect of channel/ choose one / if tv is digital in line w/dvd is digital.
If your your recorder is analogue choose use analogue channel.
Dec 14, 2007 | LG DR-4912 DVD Recorder
LG DR-4912 DVD Recorder Logo
228 people viewed this question
