Question about LG LRFD25850 French Door Refrigerator
The digital unit fell downt and burned the line inside of the refregerator. Some small holes in the melted top of the refr. LG had extended my waranty for 30 days. The repair guy came today after 2 weeks of calls and ordered the digital unit. However, when I asked him if the holes will affect the performance of my refr he called to the tech support, and they said it will not affect. I think they are not right and want to take some legal actions against LG. If somebody can help me with that I will appreciate it
  • 1 more comment
  • finberg Mar 07, 2009
    Thanks. But I do not believe it. if you have some holes in your house the air will be drifted and it will cost you more to heat or to cool the house. Same thing with the fridge. Plus it does not look good
    Thank u very much. I understand that there is the insulation, however there the space between the insulation and the liner, that helps to keep the cold temperature steady (air insulation). It is broken now so it will not work properly. I can not predict how it is going to work now. It should work like the space between the insulation in the house and the walls. Can not do anything against the science. The aerodynamic laws are the same for everything and everybody, even this LG. I filled up complaint in BBB. Gonna see what happens.
  • finberg Mar 08, 2009
    Thanks again.
    Sincerely, Ed Finberg
  • 163 Answers
It most likely wont effect the way the ref. functions.
Posted on Mar 06, 2009
  • mike cooksey Mar 07, 2009
    Behind the liner of the ref. should be insulated so it shouldnt effect the temp.I do understand it does not look good,but should operate fine.LG is a fairly new company and i personally think they are over priced for a ref. that is already falling apart.I would continue your actions on getting a new ref. to replace the one you have.Good luck.
    LG is a very hard company to deal with.but eventually everything works out.
Washer leaks but onlyu during drying cycle
the main drama i have with these lg washer/dryers is the drying vent blocks up with lint which causes excess heat build up around the heater and it often results in a small hole melting through the front tub under the heater vent where it joins to the plastic tub, it also results in water leaking out the melted hole when it dries but not during the wash as the hole is at the top of the tub, parts are relatively cheap for what they are but its a massive job to replace the front tub.
Feb 04, 2017 | LG WM3987HW Front Load Washer / Dryer
Burning smell from dishwasher
There is a heating element located on the bottom inside. Make sure you do not have anything that fell on it. And make sure it's in it's brackets it could be resting on the bottom of your dishwasher and melting a hole through the bottom.
Sep 04, 2014 | Dishwashers
JZ300 Autofocus not working
Beyond sand getting in, the lens may have been damaged from the impact if it fell on the lens while extended. It may need to be serviced by a technician.
Apr 13, 2014 | FUJIFILM FinePix JZ300 Digital Camera
Ad 18
Three things come to mind:
A) High humidity has overwhelmed the defroster & blocked the passageways so air will not circulate. (Put important food in a cooler, turn the temperature dial to off & leave doors open until ice melts out. Generally overnight. Be prepared to mop up excess water)
B) Defrost timer stopped working. (Generally behind a cover panel on the fridge side. Un-plug unit & remove panel to find a small metal box in the airflow path from the freezer. They generally have provision to manually turn the timer wheel with a screwdriver. Plug back in & allow to run & see if the ice melts. If so, the clock motor is shot. Replacements can be bought on-line)
C) Burned out defroster heating element. Generally older units. (Un-plug & put essentials in a cooler. Remove cover panel on freezer side to expose cooling coils. Allow ice to melt overnight, (again, lots of water). In the AM you can see the glass tube enclosed heater coils. All dark & smokey inside, heater is burned out. Replacements on-line for ~ $75.) If the unit is more than 15 years old, consider a more energy efficient replacement.
Good Luck!
Jun 29, 2013 | Kenmore Refrigerators
Hello. I have a kitchenaid KSSS36QBX00 refr. It looses power once in a while. There is an on/off switch on the front top of the unit. if i turn it off then on the refr powers up and all if fine. Can...
could be a bad switch, I have actually encountered this problem with this refrigerator several times. Just examine the switch and make sure it isn't burned
Mar 31, 2011 | KitchenAid KSSS36QK Side by Side...
I have a Kenmore Refr. Model # 795.77563600 has a Error FF
The FF error code indicates that the freezer fan motor is defective.
You need a new main control board and evaporator fan motor.
The fridge is made by LG, but rebranded as Kenmore by Sears. First 3 digits is the tell. You can call Sears for parts.
LG refrigerator repair in orange county, ca
Feb 05, 2010 | Refrigerators
My GE double oven JKP26GP broiler burned out (burned a hole right thru). The keypad immediately went blank and the keypad controlled top unit isn't working now (top unit only - bottom is fine). Will...
I'm afraid I don't know how to help you get a new control panel (part #WB36K5065 is no longer available). But we have the same oven and a similar problem. Our control panel works just fine, but the face is melted from a recent mishap (small fire in the upper oven while broiling), so the plastic face of the control panel looks awful and needs replacing. If you decide to replace your oven and would like to sell the front face to your control panel we'd love to purchase from you.
Nov 21, 2009 | GE Ovens
Original lamps producing excessive heat.
there is a recall for that problem you need to contact LG and they will send a repair kit for your refrig. it should be repaired at no cost but be sure to ask them.
Jan 19, 2009 | LG LFX25960ST Stainless Steel French Door...
Small earrings fell into holes on bottom
if they fell through those small holes doubt you'll find them something that small would probably be pumped out and down the drain ..if you haven't used washer since may be lucky enough to find them in pump but doubt it pump is pretty strong and can handle almost anything except socks and thongs
Sep 11, 2008 | Estate TAWX700JQ Top Load Washer
Samsung S800
If the camera fell on it's lens it is probably jammed. Try to find something small, strong and thin, possibly a hairpin and slide it into the barrel while gently trying to force it outwards immediately after switching it on. When it does extend, try to clean or blow out any grit that may be inside the mechanism. The batteries are hot as your camera does not switch off and may be remain on for hours
Feb 23, 2008 | Samsung Digimax S800 Digital Camera
LG LRFD25850 French Door Refrigerator Logo
63 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
