Question about Fisher and Paykel DGGX1 Electric Dryer
While drying the dryer stops running every few minutes.
Some time ago the dryer hardly started. It was serviced by a technitian who replaced the electrical filter. The starting problem was solved, but the dryer started stopping and runnung. Each stop lasts for a few minutes.
What is the problem?
Have you checked the hose and ductwork to make sure it's all clear? It might not be able to ventilate.
Posted on Mar 06, 2009
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
Frigidaire dryer dries for a few seconds then stops and lights blink.
Hi laylabetes - Answering your question, there isn't a way to actually CLEAN the control panel. Depending on an actual diagnose from a professional, the part would need replacing or if possible repair. However, if your model is electric, turns and there is no heat, it could possibly be a blown fuse. There are two house fuses that supply voltage to your dryer circuit in your fuse box. If one of the two is blown, the dryer may turn but will not heat. Check and replace fuse in fuse box if necessary. Please feel free to reconnect if this does not resolve your issue - Best, Chris
Jul 01, 2013 | Frigidaire Dryers
I start time dry for 60 mins. It will run for
The heater element is not heating, they are fragile easy to get to at the back of the dryer. Check the thermal or overheat switch too, but would bet its the heater element.
Nov 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't stay running, shuts off after a few minutes.
Maybe the timer or wires not hooked up right or motor if u hear like a buzzing sound when u push start it's the motor
Oct 30, 2009 | General Electric DWXR463EGWW Dryer
Humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Kenmore C11084 7029 0 dryer will not start
replace the main motor you have bad motor
Nov 12, 2007 | Dryers
Fisher and Paykel DGGX1 Electric Dryer Logo
214 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
