Question about Canon PowerShot SD790 IS Digital Camera
USB DEvice not recognized
Jvc everio gz mg130 worked fine month and a half, then all of a sudden I get this error message when trying to connect to pc....What's wrong?? USB Device not recognized...computer wonk recognize my
Everio so I can't backup and clear memory....I'm out of memory "usb not supported" shows on camera while trying to connect to PC. My camera used to work fine on my old laptop, i just connected it using a cord from the camera to the laptop and the images downloaded automatically. I have a new laptop because the old one crashed, now i have installed the software and when i try to download images from the camera it first says that the hardware is installed and ready to use, then another pop up window comes up to say "USB Device not recognized" - One of the USB devices attached to this computer has malfunctioned, and windows does not recognize it. - i have uninstalled and reinstalled the software and nothing seems to be working. I connect the printer through the same USB port and that works fine just not the camera...please help...
  • Nathaniel Nutman May 11, 2010
    Hi ,
    Is this the only device connected to your computer?
  • 95 Answers
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Posted on Aug 12, 2009
SOURCE:
I have JVC Everio GZ-MG630AU camcorder and when I connect to my computer, it just says USB Device Not Recognized. I have Windows Vista and have tried all of my USB ports to no avail. My email is...
Please check the camcorder with another PC so as to confirm the hardware in the camcorder. If this is not detected then there are errors in the camcorder main processing section which is not interfacing with the external port.
however if the camcorder works with another PC then it is possible that you PC has to be reinstalled with the OS and the drivers.
Feb 05, 2011 | JVC Everio GZ-MG130 Camcorder
Hi i have an everio gz-mg 135 and when i connect it to my pc to back up files the message "usb device not recognised. One of the usb devices attached has malfunctioned. Windows does not recognise...
- Make sure you have been installed JVC driver on your PC - If your PC has multi ports USB, just try other ports to make connection - check your firewire, it may be malfunctioned . Try other USB cables
Jan 16, 2011 | JVC Everio GZ-MG130 Camcorder
What do i need to watch video for mac computer for a jvc everio gz-mg130u? I tried everything to get to watch the video. This for a mac book
try to connect the cable of your cam through the USB type ...insert in to PC... then, data storage must be select to open the file in your computer..
Oct 19, 2009 | JVC Everio GZ-MG130 Camcorder
I cant find the charger to my Everio JVC GZ-MG330HU and wont work
Computer USB output does not provide sufficient power. Look on Ebay, buy a new charger
Jul 31, 2017 | JVC Everio GZ-MG130 Camcorder
I had a problem like this -- tried plugging the camera in to the rear USB slots not the front ones and it worked fine.
I think that it doesn't like going via a USB hub, but wants a direct connection. All of the USB ports on my computer are connected direct to the motherboard (i.e. none are on PCI cards or anything), but looking at the hardware info for the computer, it looks like the motherboard has a few "direct" USB connections, and then an on-board hub which the front ports connect to. If your computers are the same, that would explain things. I'd suggest trying each USB port one at a time (turn the camera off before plugging in, and back on when in) and see if one of them works. Wouldn't hurt to power the camera from the mains at the time too.
Jan 01, 2009 | Video Cameras
Jvc everio HDD ERROR!
first u connect to computer via usb then format it ( try to format with camera first) then preset ur camera by menu option then ur camera will be ok
Dec 22, 2008 | JVC Everio GZ-MG130 Camcorder
JVC Everio GZ-MG130 can use as webcam?
There is a program i heard of halled trackercam but for somereason it doesnt work with my jvc, im not sure why.
Sep 27, 2008 | JVC Everio GZ-MG130 Camcorder
Everio gz-mg130 won't work with vista
It is easier to connect your camcorder through the included "PowerCinema NE for Everio". First (since you're running Vista), you have to download a patch. Here is the address: http://www2.cli.co.jp/products/ne/update_everioM7SD/pcm4e_update.htm
Note: Only after you have installed PowerCinema NE for Everio can you install the patch. After you have installed the patch, just connect your MG130 to your computer through the included USB cable. Then the software should run automatically.
Hope this Helps
Eric
Dec 29, 2007 | JVC Everio GZ-MG130 Camcorder
Canon PowerShot SD790 IS Digital Camera Logo
608 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
