Question about Kenmore 24 in. 16262 Built-in Dishwasher
Kemore Elite 16262 humming sound only
I have a Kenmore Elite dishwasher 16262. When I try and start any cycle, rinse, etc. it just makes a low humming sound and it seems I can hear a little bit of water movement?Any ideas?? It is about 4 years old I would guess.
  • 163 Answers
Your motor is bad.
Posted on Mar 06, 2009
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Samsung dishwasher dmt 300rfb wont drain and is humming
Hello Randy Lowe,
There is an EXPECTED INITIAL failure period
on new equipment...!!
Use your warranty...
Brand new = Take it back & get a GOOD ONE.
Carnac the Magnificent
Apr 22, 2017 | Samsung DMT300RFS Builtin Dishwasher
I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My kenmore elite leaves food all over my dishes and utensils when the cycle is over. what would the problem be
Try rinsing all of the food off the dishes before u put them in the dishwasher, also run the hottest water u can into the sink before u start the dishwasher.
Mar 06, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
My kemore dishwasher is holding water after the cycle is over.
Usually it is due to poor draining ie. garbage disposal clogging etc... If it connected to the garbage disposal get a bucket, disconnect drain hose and run rinse and hold drain line over bucket to see if it is draining at all. It should drain completely if it is showing it is trying to drain it is a blockage in the pump underneath. but try the hose first and go from there.
Jan 28, 2009 | Kenmore Dishwashers
Kenmore elite dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 24 in. 16262 Built-in Dishwasher Logo
399 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
