Question about Samsung Propel A767 Cell Phone
I really want a signature on my propel and i can't have one i was hopeing someone new another way that i possible could.
  • Anonymous Apr 01, 2009
    i have the same problem. I have a propel as well and i want one desprately. DDDD:
  • liznewcome Apr 05, 2009
    I really need one too, and would like something to be done so we can. Most older phones have them and ALL new phones do except ours:(. Surely there is someway they can add it to our phones! Otherwise I'm going to have to get another phone. I like everything else about this one, but a signature is important to me and my line of work!!!
Well, it's not really a signature but it works.. ugh, You just add what you want to say as a text template then you go to new message the options the INSERT then text template and find the one you have made! I to have done this!
Posted on May 21, 2009
How do you replace the propeller on the Air Hogs Sky Stunt, Blue?
To replace the Propeller on an Air Hogs Sky Stunt plane (I got this from their customer server number):
1.) Hold the propeller and turn the nose (at the grey plastic edge, not the rubber) counter clockwise (aka left) until the nose unscrews.
2.) Slid off the OLD propeller.
3.) Slid on the NEW propeller (You will notice there are slots on the propeller mount), need to line up the propeller with those slots.
4.) While holding NEW propeller, screw the nose back on (similar to step # 1) clockwise (aka right).
Hope this helps someone else.
Mar 15, 2013 | Toys
Odometer and speedometer not working, signal light and high beam light work on cluster
The turn signals on my 2005 Honda Shadow Aero 750 also kept blowing the fuse every time I turned them on,discovered a short circuit in the wiring harness running from the instrument cluster to the turn signals etc.whenever the handlebar was turned fully towards the right the bare wire would make contact with the frame causing a short circuit and blow the fuse.Corrected this by taping the bare wire very carefully.
Problem solved.
Dec 03, 2012 | 2004 Honda VT 750 Shadow Aero
Can you save a text template to be put on your texts every time
Yes, it is actually called a signature. Go to your message settings and you should see signature option, select that and then add the text you want to be on your messages. But make sure that your signature is turned ON in your message settings. Hope this helps!
Mar 28, 2010 | Samsung Propel A767 Cell Phone
Self-propel switch arm broke off where control cable was attached. Looking for instructions as to how to gain access to that switch arm to replace it.
Greetings from GoVacuum,
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
We have also put together a very helpful video for your vacuum cleaner on how to replace the belts. The belts on this model are also a frequent issue we see with these self-propelled Winddtunnels. In fact, for best results you should change the belts once a year, even if they are not broken, because they do heat up and stretch to a point where they don't work as well as a new belt would. The video also explains how you can maintain the roller brush will help you get the longest life possible out of your belts.
Video Repair on How To Replace The Belts Hoover Windtunnel Self-Propelled;
I hope that this information was helpful to you in repairing your Hoover. If you did find this helpful, may you please rate the repair by clicking the the Thumbs Up Icons in the top right hand corner of this repair to help me start out here on Fixya? I really do appreciate it, thank you so much!
Feel free to request a repair clarification if you have any questions or concerns you'd like to address.
Chris J.
GoVacuum
Feb 22, 2010 | Hoover Self-Propelled WindTunnel Bagless...
I have the following error when I lunch google chrome. Can someone help Problem Event Name: AppHangB1 Application Name: chrome.exe Application Version: 0.0.0.0 Application Timestamp: 4ac64269 Hang...
you need to reinstall chrome because there is a corrupt or missing file needed to remain stable........click here to get it....when ur done make sure you remove all other internet browsers and set chrome as your default...you should be good to go. Good Luck and pls rate this post!! :D
Oct 08, 2009 | E-Machines eMachines Desktop PC
18 hp briggs will run for a little while then die. Checked coil and new gas
It's possible that you have condensation built up in your carburator. Tiny droplets can deny gas to the cylinders. Since you put in new gas and I assume you are getting spark, drop the bowl on the carburator and check for this culprit. Could be a quick fix.
Hope this helps... Good luck!
Oct 04, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
My samsung propel a767 will not send/recieve picture messages
if your internet is not enable.....then u CAN NOT SEND PICUTURE MESSAGE NOR RECIEVE THEM.....all u have to do is call customer service to to enable your internet (u will NOT be charged with no fees) UNLESS U GO TO THE INTERNET..............THIS WILL MAKE IT POSSIBLE FOR U TO RECIEVE AND SEND PICTURE MESSAGE................HOPEFULLY DIS INFORMATION WILL BENEFIT
Mar 28, 2009 | Samsung Propel A767 Cell Phone
HOW DO I PUT A SIGNATURE ON MY PHONE
the propel does not have the signaturee
Mar 21, 2009 | Samsung Propel Cell Phone
Signature pad writes straight line instead of signature
you can either try to unplug the pad for a minute. or uninstall the pad and then reinstall it again. and if that doesnt work then someone watered or damaged your pad some how.so you would have to buy a new
Dec 01, 2008 | Computers & Internet
Samsung Propel A767 Cell Phone Logo
127 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
