Question about Samsung Televison & Video
Samsung TXE2746 Just can't start, the relay  make the sound  for "on" and in less then a second switch off, and again and again , after that I have to unplug the Tv to make it stop. I have a similar power switch problem with TXE 27 46. There is no remote control but once you switch on the switch button, it makes a click sound. Then it goes off and on off and on indefinitely. [that is click..click.. click...etc.]. Is there a solution to this problem. Could someone out there help? This make was purchased in 1997. Do you suggest that I dump it or try. my contact is mayrinbuyer@yahoo.com
  • 373 Answers
I have fixed this problem many times. To start you must unplug the set and take the back off.
Close to where the AC plug cord goes in next to the relay which is in a small plastic box about 2 inches long and 3/4 inch wide and 2 inches high there is a capacitor which is a cylinder type component that has the location of c858 and it has two connections one positive and one negative. You can see the negative sign on the side of it. It should have the number 470 and 25 V on it too. This part is bad and must be replaced. Unsolder old and solder in new. You can get at Radio Shack for around a dollar. When you put the new one in it must be correct negative and positive as the one took out. Be sure to make good solder connections
This will definitely fix the problem
Posted on Mar 06, 2009
Ive got a 1997 cavalier it will start but quickly dies out ive got fire to my plugs and fuel to the injectures ive just replaced the ignition switch is there somkind of a security
You need a new fuel pump relay. The engine fires up and runs off the oil pressure switch untill the oil pressure PSI is reached at normal operating conditions. When the oil pressure reaches its operating PSI the PCM or engines computer will shut off that circuit and turns on the fuel pump relay to run the fuel pump untill you shut the engine off
Apr 19, 2010 | 1997 Chevrolet Cavalier
Plano tv samsung txe2746
saludos tengo un problema en la fuente de alimentacion y exploto el integrado que esta unido a un disipador de calor precisamente en el serial del integrado quien me podria ayudar facilitando el plano electrico del samsung txe2746.
gracias
Jan 07, 2010 | Samsung TXE2746 27" TV
It starts but then it turns off in less then 10 seconds
Sounds like bad relay or ignition switch; check relay first.
Nov 30, 2009 | 1999 Pontiac Grand Am GT
SAMSUNG TXE2746 Switch makes click sound and does not switch on
I was thrilled reading our kind Forumite's instruction on how to get my broken Samsung txe2746 wiht the above problem repaired. The cylinder specified located at C858 supposed to be numbered 470 turned out to be the wrong one. The one with that specification is C808 with the number 470, and 25V. Did I misread your instructions or it could be that mine is a different model? Should I go ahead and change the C808 just for the sake of trying. Is this recommended?
Mar 06, 2009 | Samsung TXE2746 27" TV
Picture tube
HELLO
If your tube has gone and you are looking to replace it - my advice is don't bother - it will cost you dear in the end. The best thing to do is try to get another CRT TV set (maybe a different make/model).
It is a skilled job replacing a TV tube and should not be attempted by anyone who does not know what they are doing!!! In the wrong hands a CRT is dangerous and could cause serious injury if dropped or handled incorrectly (it makes one hell of a bang).
I wish you luck with it all the same (:-)
Jan 18, 2009 | Samsung TXE2746 27" TV
TV switch off randomly
It is a Rely in the Power Supply. Need to have it changed out. Cheap part.
Dec 29, 2007 | Samsung HP-R4262 42 in. Plasma Television
Samsung TXE2746
this could be a number of problems first chek the horizontal output transistor this could be shorted and the set could be tring to turn on but cant couse of the short look for bad solder connections if this does not help check or replace the regulator
Nov 02, 2007 | Samsung TXE2746 27" TV
Televison & Video Logo
69 people viewed this question
Henry  Thomas
Henry Thomas
