Question about Seth Thomas Radio-Controlled Howard Wall Clock - SET717
I can't set the clock. The hands keep turning and
I can't set the clock. The hands keep turning and stop at 12:00. How do I set this atomic clock?
  • 4 more comments
  • Anonymous Mar 09, 2009
    RESET USING RESET BUTTON BUT GOES BACK TO NOON!
  • Anonymous Mar 11, 2009
    same problem
  • Suzbluafyuz Apr 15, 2009
    We have the same problem. The old battery was apparently dying, and the second hand was moving very slowly, and we couldn't set it to the correct time. After putting in a new battery, the clock set itself to 12:00 and we can't get it to set to Central Standard Time.
  • Suzbluafyuz Apr 22, 2009
    I was able to set the time, but it only stayed at the correct time (Central Standard) for a little while, and then it reset itself to one hour earlier. We're on Daylight Savings time now, but the clock won't let me set to the correct time. Don't know how to correct it.
  • browneyes397 Apr 30, 2009
    same problem. technology could be so stressful sometimes.
  • dwehayward Apr 30, 2009
    IT is a new clock when I hit the set on it it just goes around untill it gets to the 12:00 then stops. It acts as though it is searching for a signal.
Look at the bottom right of the back of the clock and find the "M Set" button. Simply hold it down and the clock will move (very slowly). When it gets to the correct time, let go of the button. After that, the radio controlled shoul dcontrol should correct any minor differences in time.
Jim
Posted on Aug 11, 2009
I have a toll free number. You can try it: 1-800-242-6300
Posted on Apr 22, 2009
HI I live in Hawaii we dont go by pacific time zone like California how do I set my clock WT-3122A
Aloha. Try asking your question here: Clocks Watches Questions . They helped me before with an antique clock problem. Good Luck.
Oct 04, 2014 | La Crosse Technology WT-3122A 12.5" Wood...
Setting clock on laptop toshiba need to find out how to change time on laptop pc
Click on the clock time and you can edit the time and date.
The clock time is on the bottom right hand side of the desktop.
Feb 07, 2014 | Toshiba Computers & Internet
Minute hand on atomic clock keeps moving
Take the battery out and put it back in the opposite direction. Wait 5 seconds. Put it back in the correct position. The minute hand will go around very fast and eventually come to a stop. This can take a couple days. That means it is waiting for a radio signal from Colorado. For a better signal, place the clock in a window that is facing Colorado. The minute hand will begin to spin very fast until it stops at the correct time. Again, this could take up to 2 days.
Sep 12, 2012 | Staples Round Atomic Wall Clock; 14
The second hand on our LaCrosse atomic clock has stopped moving but the clock continues to keep perfect time. How do we get the second hand turning again?
The manual for one of their clocks says the clock will change the second hand to two-second intervals to conserve energy when the battery voltage gets low. Perhaps your battery is VERY low.
Mar 25, 2011 | La Crosse Radio Controlled Atomic Clock
Atomic Clock by SkyScan model # 28600. Clock
It does that until it receives a signal. Leave it overnight and it will probably get one. Instructions for this clock are at skyscaninfo.com
Apr 04, 2010 | SkyScan 86709 Atomic Wall Clock
My Barolo atomic wall clock (with hands) stopped working (I think the battery died). I replaced the battery, and now the hands just keep going around without stopping. I have removed & replaced the...
Try to move the clock to a different place. Atomic clocks work by receiving a radio signal. If it has no reception, it may do that. However, I would suspect that no reception would lead to it not setting at all(at least based on the ones I've seen) and it may be something wrong with it (i.e. having difficulty detecting where it's hands are) Good luck.
Jan 03, 2010 | Kitchen Appliances - Others
Hands on lacrosse atomic clock won't stop spinning.
remove everything to get to the hands, remove the top hands only leaving the one, carefully apply crazy glue (tiniest sliver) to the hand where it meets the shaft. Adjust that hand for one minute after the current time. wait about 15 seconds between each hand. Apply the others remembering to set the others to the exact time. let it dry and you should be done.
Jul 04, 2009 | La Crosse Radio Controlled Atomic Clock
Instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
Nov 03, 2008 | SkyScan 86709 Atomic Wall Clock
Savings time
This is more of a Clarification than a solution.
I've determined that the SS-5000 is not recognizing the changes to DST that happened in 2007.
From 1986 to 2006 this was the first Sunday in April to the last Sunday in October, but starting in 2007, it is observed from the second Sunday in March to the first Sunday in November, adding about a month to daylight saving time.
So in March the clock is still trying to keep the "earler" time and in November it's trying to keep the 'later' time.
I'm contacting HomeMedics Support to see if there's a resolution.
Mar 17, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Seth Thomas Radio-Controlled Howard Wall Clock - SET717 Logo
4,231 people viewed this question
Top Seth Thomas Audio Players & Recorders Experts
Dennis Key
Dennis Key
Vito Vacirca Jr.
Are you a Seth Thomas Audio Player and Recorder Expert? Answer questions, earn points and help others
