Question about Kenmore Washing Machines
Washer isnt spinning? motor is working but it is not spinning
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
THE DRUM ON MY MACHINE ISNT GOING AROUND AND IT'S NOT SPINNING
Is it old washing machine?
One problem could be belt. It could be dropped. If you hear motor spining noise, but drum isnt spining - this is it.
If you cant hear anything - motor carbong brushes..
If not - electronics problems (semistor or etc).
I need more info to help you better.
Apr 05, 2013 | AEG Lavamat 74640 Front Load Washer
My washer will not go into spin cycle my wife says she can hear the motor running but it isnt spinning
You might wanna check the belt. It might have gone out of the spinner rail or is broken.
Sep 12, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washer will not drain water or spin
Check your drain pump motor. water isnt draining properly or not at all. It could be either something stuck in the piping (drainage), or the pump is not operating.once rectified, it should work properly again.
May 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't spin
check the lidswitch under the lid. if it is not clicking or is broke the washer will not spin. you may need to replace it or you could have a bad timer. if it isnt agitating or spinning and you here the motor running you could have a bad belt or coupling
Sep 17, 2009 | Washing Machines
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
hi, Does the water drain out in the spin cycle? Sounds like the coupler might be bad. Is this a top load machine? Asking questions so I can be clear and give you better info on your question.
Please let me know.
Thanks
Vic
May 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Roper RAX4232KQ0 maker loud noise at spin cycle and then stops
There are a few things that can go wrong, If the washer doesn't adgitate or spin then probably the coupler is broken, lean the washer back and look under the machine between the motor and transmission you will find the coupler. (very common)
Coupler Part# 285753A $22.95
If its agitating but not spinning, check the lid switch, (easy check just listen for the click when you shut the lid, Or you can bypass it with a jumper wire under the console there are only 2 screw that hold the console down they are philips and either located in the front lower corners or the back lower corners)
Lid switch Part# 3949247 $42.95
If lid switch is good and the motor still doesnt run you might have a bad timer (RARE)
Timer Part# 3954563 $95.95
If you can hear the motor running but its not spinning and you have rulled out the coupler then your probably looking at a clutch (common problem) either the clutch isnt grabbing or the brake isnt releasing both problems solved with the clutch kit
Clutch kit Part# 285785 $44.95
Worst case your looking at a transmission, (uncommon) to rule out, make sure its agitating, then put washer in spin cycle. look under the washer to see if the clutch bell is spinning. if its not then you will need a transmission.
Trans Part# 3360629 $172.95
if its making loud noises when it stops spinnig then the block is bad.
Block Part# 389140 $14.95
Feb 07, 2009 | Roper RAX4232KQ Top Load Washer
My servis washing machine turns and empties but wont spin machine isnt spinning
I suggest you remove motor and check the carbon brushes fitted at the end of the motor, if they are less than 2-3mm long ,they need replacing.
Plz rate my solution
Thanks.
Jan 04, 2009 | Tricity Bendix AW1000W Front Load Washer
Kenmore spin cycle issues
Does it agitate and spin at the same time? the motor has a pump on one side and gear case on the other. if the gear case is seizing then the pump is lagging because the motor is loaded from a seizing gearcase and the gear case needs to be replaced.
Aug 24, 2008 | Kenmore 24032\24036 Top Load Washer
Washer does not spin
May want to check out the belt on the bottom. If it got wet, it may have stretched it out to wear it wont work. The tension is caused by the motor sliding in and out on a sliding system, which may have gotten a little rust in there. Make sure the motor will move somewhat freely and that the belt isnt stretched to much. Might be an easy fix. Good Luck!!! Jim
Sep 08, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
18 people viewed this question
Sal De
fordexpert
Robert Rankin
