Question about Maytag 7.0 Cu. Ft. Electric Dryer
My simpson maxidry 505 dryer is not heating
For some reason it is not drying the clothes. I ran it for 10 minutes without any clothes and found out that it does not creat much heat.
Any assitance would be great.
  • 11 Answers
SOURCE: Maytag Atlantis MDG7400AW Gas Dryer not drying clothes
This problem doesn't sound right, but you could have a bad moisture sensor.
Posted on May 20, 2007
Illeagle
  • 525 Answers
SOURCE: Maytag MDG7600AW Gas Dryer heat starts and then stops
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance. Clicking on the underlined links will take you directly to that page.
If your dryer doesn't heat properly, check this: Venting restriction: Disconnect the dryer temporarily from the vent. If the flame stays on for a longer period, you may have an air flow obstruction to the outside. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Also, in your case, the coils may work fine initially, but heat build up can cause the coil(s) to malfunction and when they cool down will work again.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3479&PPStack=1
This link will help you with disassembly and diagnostics diagrams.
http://www.repairclinic.com/0100_17.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
SOURCE: Simpson Sirocco 350 Dryer not heating
there is an oval cover on the back of the dryer. Remove this cover and you will probably find a broken fan belt. A replacement costs about $20 Aus.
NOTE: If you have been using the dryer for a while in this condition there will certainly be moisture inside the dryer. Replace the belt and leave the dryer for a few days to dry itself out (motor and electricals) before firing it up.
Posted on Feb 25, 2009
Healeyman
  • 1198 Answers
SOURCE: maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Posted on Apr 28, 2009
  • 2672 Answers
SOURCE: my dryer get to hot is simpson maxidry 505
sounds like it needs to be cleaned out,check outside to seeif the flapper is blowing open or if it is clogged with lint,if you have a leaf blower take vent line off of back of dryer and blow it out,vac inside of dryer and clean out the lint filter duct,if it's gas you should do this every year so you don't have a fire,electric every two years
Posted on Nov 08, 2009
Can you please tell me where I can get a Simpson Maxidry 1000 user manual or any other kind of manual for this dryer?
Try this link:
http://fasterbetterdownloads.com/simpson-maxidry-1000p-user-manual/
Jun 20, 2015 | Dryers
Air no longer venting out back of dryer
sounds like the fan not working.
Apr 06, 2013 | Dryers
Simpson Maxidry 1200 S Clothes Dryer. Dryer spins, Blower working, but heater doesn't work. I've got the element out & it checks ok. What next please?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Dryers
Hi, My Simpson maxidry 456 dryer, heats up and appears to work, gets hot and cuts out. It is steaming the clothes but does not dry them. Would this be a fan problem, How can i fix it? Ta!
9 out of 10 times this is going to be a restriction in your vent line. Check where it goes outdoors and see if there is a steady flow of warm air. If not, take the vent off of the wall behind the dryer and either have a handyman snake it clear to the outside or take a leaf blower and blow it clear. A good way to test for a restriction before doing all of this is to run a cycle with the vent disconnected from the back of the dryer. The steam is a result of the hot wet air from the clothes having nowhere to go. Good luck =)
Jul 28, 2010 | GE Dryers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
G'day my Simpson Maxidry 1000 is spinning but is not heating up
the element is at the front of the unit.if u have no heat it is proberly your element, broken wire, timer or thermostat. if u have an electrical test meter i can tell how to test 4 faulty component. 90% of the time i have found it is the element . please reply 4 more help. element replacement is not too expensive.
Apr 12, 2010 | Dryers
My dryer get to hot is simpson maxidry 505
Nov 08, 2009 | Dryers
Simpson Maxidry 1200 S Cloths Dryer. Our dryer whilst spiining and heating is not adequately drying clothes. When I took it down to check test it appears that the belt to the central lint fan may have been...
Yes - the vent exhausts humid air, and draws IN fresh dry air. So the humid air is staying trapped in your unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 08, 2009 | Washing Machines
How to fix a Simpson Maxidry 1000p?
Idler pulley and spring have come off while cleaning dust from inside cabinet a diagram whould be a great help as Im 500kms from nearest service place simpson maxidry 1000p Ray bushed
Jul 26, 2008 | Dryers
Maytag 7.0 Cu. Ft. Electric Dryer Logo
189 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
