Question about Samsung 52 in. Flat-Panel LCD HDTV
Brand new samsung tv. plugged into cable box.
Brand new samsung tv. plugged into cable box. Have a red light on bottom right of tv - but no picture. any suggestions.
Thanks
    Sergeant:
    Champion:
  • 267 Answers
Return to seller or take authorized servicer.
Posted on Mar 16, 2009
When the TV is plugged in the screen is black,little red power light bottom right corner blink 5x then you hear the sound of power on pause then power off. This continues to repeat and no picture.
Repairing Flat Screen TV - Blacked out with blinking red light
? 12:00
https://www.youtube.com/watch?v=3GmtBthpzDk
Mar 15, 2012 - Uploaded by n1bpd
Repairing Flat Screen TV - Blacked out with blinking red light ...Capacitors are little cylinders with a flat top with an X. If they have failed the X .... picture, no sound, totally black just the red power light blinking on the corner ... hello i have a dynex dx-lcd42-09 the red light blinks as soon as i plug it in i opened ...Missing: 5x
comments on EASY HOW TO FIX SAMSUNG TV- NO POWER
https://www.youtube.com/all_comments?v=hgcmWO7mqmo
Dec 16, 2015 | Samsung 55" UN55D6420 3D LED TV Smart TV
I have a Samsung 46" TV (LCD) which will not display a picture. The white light in the bottom center area lights up and the Red Light in the bottom right hand corner continues to blink. Finally, about...
had a totally knackered Samsung power supply which had to be replaced when I fitted new psu had clicking coming from new psu which turned out to be a faulty relay on the new Samsung p.s.u replacing the relay on the new power supply board got the TV working 100%
Mar 26, 2015 | Samsung Televison & Video
No picture can hear when i power off and on with no red light
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 24, 2012 | Samsung LN40B530 40 in. LCD HDTV
WE are trying to hook up our new cable box. We cannot get the TV to go on. A red light keeps flashing.
What brand and model is the t.v.? Usually a red blinking light is a code meaning something is wrong. Watch how many times it blinks and post the brand and model of the t.v. and how many times the stand by light blinks. First unplug it for at least 2 minutes and re-check all the cable connections to make sure they are plugged into the right places. Then plug the t.v. back in and turn it on first before you turn the cable box on. Good Luck, hope this helps.
Jul 31, 2011 | Memorex Televison & Video
Wii is not in color on new samsung led tv
in the component area o
n back of tv connect wii's cables to the bottom row. yellow = bottom right with yellow circle and red and white to then going to the left and skipping 2 holes plug red and white into audio left and right . then set source on tv to AV
Dec 23, 2010 | Nintendo Wii Console
Lcd tv hookup
Ive got 3 samsung tv's (lcd, plasma, DLP) and I use HDMI cables on all of them. Its the only way to get the full potential out of the tv. When you use the red/white/yellow RCA cables the signal is anolog aka "old technology". Component cables are good but HDMI is the best. HDMI is a digital signal and thats what all the components that go with the tv should be run on. If your dvd player does not have an HDMI output I would suggest getting one that has that output. As for the cable box most require you to upgrade to digital cable in order to get one with an HDMI output. If you dont want to spend the money on new components and run what you have now the picture will stay mediocre at best. Good luck hope this helped
Mar 07, 2009 | Samsung LN32A330 32 in. LCD TV
Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Dec 01, 2008 | Samsung T240HD 24 in. LCD TV
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Samsung HCN4226WX/XAA Rear Projection 42" TV Wont Turn On
take off the back there is a board at the top right with two black stk-392-040 chips on it unplug the red connector at the left side of the board then plug set up and see if it comes on if so the chips on the board are bad or replace the board about $100.00
Aug 02, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung 52 in. Flat-Panel LCD HDTV Logo
74 people viewed this question
Jerry Greenberg
Jerry Greenberg
