I have a desktop Gateway model: 650 Performance w/windows 98SE. My computer will begin to boot, Windows starts up and after about 10 seconds complety shuts down. I can access safe mode and computer stays on, but haven't been able to solve the problem. Also the "cd" nor "A" drive starts. Use Norton software. Suggestions would be appreciated should.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 80 Answers
You have a virus or you accidentally deleatd some start up files,if you instilled any new hardware then remove it and try starting up again. if not, try a system restore but you may need to either upgrade or reinstall windows.
as for the CD or A drive you can enable them to boot before the hard drive from the by pressing eigher F2 , F8, or F10 keys depends on you model. while in the system menu change the boot order and save your settings.
Posted on Mar 06, 2009
Windows 8 Gateway desktop trying to load Win7. I
Hi
You can try with Free Boot Managers and Multi-Boot Loaders you can find lot of free stuff available in online. So download and follow the instructions.
OSL2000 is an advanced multi boot manager you can install multiple OS in a Single PC.
Hope this will be helpful
Have a good day.
Regards
NANDU
Aug 28, 2013 | Gateway SX2865-UR11P Desktop Black
Hi, im trying to install windows 7 ultimate onto my gateway. I bought it retail from best buy and am having problem with the install... is it factory set for me not to be able to install an operating...
First of all you need to make sure that your machine's hardware can run Windows 7. The Microsoft website has info on everything you need to know. Google can find that for you.
Are you doing a clean install or an upgrade? That being said, for a clean install please see the next paragraph.
You may need to select the boot order. That is, it needs to boot from the CD/DVD drive first. Usually this is accomplished by: Have the Windows CD in the drive>reboot the machine and as soon as you see it begin to load start tapping the F12 key. This should put you into the selection menu to choose which device to boot from first. Also, going into F2 (setup) will allow you to select which device boots first.
An upgrade is usually started from within Windows.
Feb 24, 2011 | Gateway GM5626 PC Desktop
My gateway notebook is locked n I can't remember my user password ..help very frustrated ...I tried ctrl alt del twice to make the admin acct pop up but nothing
Try booting in safe mode.
Restart your computer.
As the computer restarts, begin pressing the F8 key after the Gateway BIOS logo appears until the Windows Advanced Options Menu screen appears.
On the Windows Advanced Options Menu screen, use the arrow keys to select Safe Mode, and then press the ENTER key.
After logging on to Windows XP Safe mode, in the Desktop dialog box, click Yes.
Good luck, post back if this helps.
Jan 28, 2011 | Gateway Computers & Internet
Cant get past error even tryed to repair windows or how can i install reinstall
Try booting into safe mode by pressing F8 when boot up starts. Choose safe mode. When it's booted up, right click on "my Computer" and choose properties. Click on advanced and choose the advanced tab. Go to performance and change the settings of Virtual Memory to what Windows Recommends.Restart.
May 29, 2009 | Gateway Essential 400 PC Desktop
I need windows 98 instalation dump or vedio
Ha! That's the first OS I ever reloaded.....ah, memories.
I most certainly can help you with this.
Here's what you need to get:
Windows 98 boot floppy from here - http://www.bootdisk.com/bootdisk.htm
(you need to know which version you are installing, Windows 98 or Windows 98SE)
Windows 98 or 98SE OEM CD
You will need to boot from your floppy disk first and format the hard drive which will prepare it for windows, then use it to boot your computer to the cd and the process will begin.
Here are some more detailed steps, the above is only in a nutshell:
http://support.microsoft.com/kb/221829
That comes straight from Microsoft. Let me know if that helps you!
Mar 14, 2009 | Microsoft Windows 98 for PC
Gateway 505gr became unresponsive, on reboot windows cannot load
Hello guys,
This problem would arise only when the motherboard doesn't work properly. Check with your nearest gateway service center to get your CPU work again. That would be the only thing to be done.
~REGARDS,
Jegan
Nov 20, 2008 | Gateway 505GR PC Desktop
I have dual boot 98SE/XP-Pro in same disk partition which got virus attack. In order to fix problem (long story), I had to remove and re-install the XP-Pro OS. Unfortunately I deleted the XP system from...
Why would you torture yourself with that old thing?  Yeah, you can create more boot script lines...they should designate the proper root for the second volume and that ought to fix any missing file issues if indeed ICG32.dll and company are where they started....
Jul 22, 2008 | Computers & Internet
My computer is extremely slow
1. Uninstall Unneeded Programs (Start, Settings, Control Panel, Add/Remove Programs) Keeps at least 10% of your HDD free, 20% is preferred. Windows uses this space for it's swapfile.
2. Scan Your Hard Disk for Errors. (Double-Click MY COMPUTER, Right Click C:, Properties, TOOLS TAB)
3. Scan for Viruses (If you don't have an updated and functional AV, http://free.grisoft.com)
4. Check for Spyware and Adware (http://www.download.com, Spybot search and destroy)
5. Defragment Your Hard Drive (Double-Click MY COMPUTER, Right Click C:, Properties, TOOLS TAB)
6. Adjust Visual Effects for Better Performance (Right-Click the MY Computer Icon, Properties, Advanced TAB)
7. Stop Programs from starting on Windows boot (Start, RUN, MSCONFIG)
Jun 22, 2008 | Gateway Computers & Internet
GATEWAY 310
I wonder if that is a computer virus.
Try putting the computer into safe mode by shutting the computer down, wait 30 seconds, turn if back on.
At the beginning of the boot press and hold down the f8 button. Use the up and down arrow keys to select safe mode and press enter.
After windows finishes starting up in safe mode, restart your computer the normal way.
If the login screen still appears that way and you can get into safe mode, I can tell you how to go into the control panel and change the login screen to the other mode. That should work then.
Jun 21, 2008 | Gateway 310S (2900621) PC Desktop
Computers & Internet Logo
David Payne
David Payne
