Question about Danfoss Sundstrand-sauer-danfoss Sundstrand Hydraulic Pump
WE ARE USING DANFOSS HYDRO MOTOR MODEL NO :OMS160 ON OUR PLASTIC INJECTION MOULDING MACHINE , I WANT TO KNOW ,HOW DO WE RECOGNISE A WORN OUT HYDRO MOTOR ANY PARTICULAR TEST TO CHECK OUT THE MALFUNCTIONING
  • 3 Answers
Limit the pressure supplied to the inlet of the motor, plug the return port. Place the case drain line into a bucket, or install a case drain line if not equiped and comparte the flow to the manufacturers specs. I don't know what they are off hand, but shouldn't be more than 1 gpm I wouldn't think. Another quick test is if you can turn the bare shaft easily with no resistance when both fluid ports are open, the geroller set has quite a bit of wear. This quick test doesn't work in some applications such as wheel motors as they are sometimes ordered as "free running" motors. They are the same motor, but with a looser fitting geroller set.
Please visit http://hansonhydraulics.blogspot.com for more information.
Posted on Mar 15, 2009
Hi, sir, we are a motor manufacutrer in China, and we also do OEM products for Danfoss. So in you want to cut your bargain, maybe you could contact us to buy motors from us.
My email: paul@fullingmotor.com
Posted on Jul 31, 2009
3D PRINTING EQUAL BY INJECTION MOLDING
3D printing and printers are the most wonderful inventions of modern science and technology no doubt! These excellence of science has made the most uncommon performance. For example human body parts are now possible to produce through 3D printers. This is some what like the injection moulding of plastic goods by a nice machine. Please visit @ http://best3dprinter4u.com/ for details.
Jan 20, 2014 | Computers & Internet
I need wirig diagram for injection moulding machine (brand,union 76, italy)
Sal-am Mohamed, This forum is for faults on motor vehicle. To find the information you require I suggest you do a Google search, typing in the name of your machine into the search bar. You can use the Google translate app if the answer comes up in Italian. Sorry for not being of more help. Shalom John
Nov 24, 2012 | Cars & Trucks
Ive got a 1845 c.i need a tandom hydro;pump. does anybody know where to find one ??
Call Nova Hydraulics 317-322-0242 x103. They are rebuilt on the shelf. Get your model code - IE: M91-46507. There are several model numbers used.
Apr 14, 2010 | Danfoss Sundstrand-sauer-danfoss Hydraulic...
I have Sundstrand Hydrotransmission the code number on name plate as follow BDP-10L-0351 87-48-10553 Please info us how to understand those nomenclature? Regards Dudy
This is now handled by Hydro-Gear. www.hydro-gear.com.
BDP stands for Bantam Duty Pump and the rest of the code calls out the configuration of your pump - shaft, rotation, size, etc.
Mar 27, 2010 | Danfoss Sundstrand-sauer-danfoss...
Charge pressure drops to zero when hot and grouls.Where is the charge pressure set? Jack
What is the model number and brand of your pump? Your description is a classic statement when hydros (your pump and motor) are failing. You can try charge pressure adj to make it work better. Model number will tell me where to direct you.
Mar 18, 2010 | Danfoss Sundstrand-sauer-danfoss...
Joe is writing, I have a Sundstand hydraulic pump mounte on a concrete Rexmixer machine. The pump can only sustain for 5 minutes working time and all sudden it won't be able to deliver enough power to the...
It sounds like your hydrostat pump and motor are failing (leaking too much). Seals will not fix this problem. Send me your model numbers for verification and further info.
Oct 19, 2009 | Danfoss Sundstrand-sauer-danfoss...
Looking for specs
You can get from BJ Hydraulics 269-623-6743
Jan 07, 2009 | Danfoss Sundstrand-sauer-danfoss...
Danfoss Sundstrand-sauer-danfoss Sundstrand Hydraulic Pump Logo
1,029 people viewed this question
Top Danfoss Garden Experts
Wayne Fellows
Wayne Fellows
Pcm2048
Andrew Taylor
Andrew Taylor
Are you a Danfoss Garden Expert? Answer questions, earn points and help others
