Question about GE GSL25JFPBS Side by Side Refrigerator
GE side-by-side GSL25JF BS no water or ice -- was working fine and just quit
Sea Breeze
  • 4654 Answers
SOURCE: no water but ice is fine
Two possibilities are water solenoids on back of refrigerator.  Switch the wiring on the two solenoids so when you ask for ice it will dispense water. If you get water when you ask for ice the solenoid is bad. If still nothing happens the control switch in the door were you switch from water to ice may be bad. When you determin you have found the problem return the wires to there correct solenoids. Hope this helps, Sea Breeze
Posted on Oct 28, 2007
SOURCE: Water and ice will not dispense
I am having a similar problem, model # GSL25JFRF-BS Through this forum it was suggested the motherboard in the back of unit may be bad, and may be under the "replacement program" due to multiple failures. Tomorrow I will call to check status of replacement. I will post the result when I have it.
Posted on Jun 15, 2008
SOURCE: GE SIDE BY SIDE MODEL # GSL25IFRF BS
did you change water filter?
Posted on Jul 22, 2008
tech master
  • 120 Answers
SOURCE: Water dispenser not working
2 things i want you to try before you call a tech out first under frezer door there is a connector where the 2 lines connect disconect both off now actuate the water at door if you get water out the line that means your line inside door is frozen 2 if you don't get water that means your water reservour is frozen so to solve problem cheapest way is to derost it by unpluging it for maybe 2 days and if it was frozen it should go back to normal and this time keep your temps in right settings refrigerator section at 37% and freezer from 0 to 4 % at all times that will keep lines from freezing
Posted on Oct 12, 2008
SOURCE: No water flow
I had the same problem.  The water lines in the freezer door had frozen up.  I defrosted the freezer, and the water flows great now.
Posted on Jan 24, 2009
I have a gsl25jf side by side. Ice will not dispense - ice continuess to be made. Water will dispense - after you try to have ice dispense from the door there seems to be a clicking sound the lights dim on...
PULL THE ICE DESPENCER OUT AND RUN HOT WATER OVER IT AND START FRESH . IT MIGHT JUST HAVE A ICE JAM, I HAVE SEEN THIS BEFORE, THE ICE BUILDS UP IN LAYERS AND WONT ALLOW THE TREY TO SIT IN SNUG TO THE MOTOR .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 27, 2011 | GE GSL25JFPBS Side by Side Refrigerator
I have A GSL25IFRF bs side by side fridge with ice and wter dispenser on the outside and I am not sure how to connect it to work so I can get ice and water
On the back right side facing the refrigerator at the bottom is a connector for a quarter inch water line. Sometimes you have to loosen the back to access this. Hook your water line up here.
Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE Profile Arctica PSS25SGNA BS Icemaker is not working seems to be filling with water but no ice.
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Nov 18, 2009 | GE Profile Arctica Stainless Steel Top...
GE Frig has water at door but no ice is made
Pour about 1/2 cup of water into the icemaker . If it dumps , replace the water valve . If not , replace the icemaker . Make sure the coils are clean of dust , etc... at bottom of fridge .
Aug 09, 2009 | GE CleanSteel GSL25JFTBS
Ice and water is not coming out. ge side by side
Check the plug to the door first. Then turn the ice machine head off unplug the refrigerator for a few minutes. Plug it in and turn on icemaker. this part problably just lead back to squre one. have someone push the button for water while you are listening at back bottom for humming sound,if you dont hear it its probably a bad water valve.
Mar 21, 2009 | GE Refrigerators
GE Profile TFT25 PR. Ice maker quit producing
Had the same problem. Replace the water filter and is should begin making ice again.
Mar 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE GSL25JFPBS Side by Side Refrigerator Logo
320 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
