Need to replace LCD screen on Equium L20-197
I have to replace the lcd screen on this laptop, (part # PSL 2ZE). I can't find disassembly manuals anywhere. Is there a step by step guide for this?
Thanks!
  • 3 more comments
  • emlyn98 Mar 06, 2009
    It's a Toshiba Equium L20-197. Part #: PSL2ZE-001002CY
  • emlyn98 Mar 07, 2009
    EL Geek. Thanks for that. I'll take photos and make copious notes. All the best.
    1 other thing, Do you think this is something someone with a mid-level hardware knowledge could undertake to replace, or should I steer clear? Also, do I need any glues for holding the lcd in place?
    Thanks.
  • emlyn98 May 22, 2009
    Thanks for asking. I got an offer of a replacement laptop, so I took it. The old one's gone off to laptop heaven. Thanks for the pointers though.
    All the best.
    Emlyn.
  • MadeletricO
    MadeletricO May 11, 2010
    what make and model labtop do you have?
    Scholar:
  • 149 Answers
I can testify that you will have an incredibly hard time finding a step by step guide on how to change a laptop screen. My best advice would be to get a digital camera and take pictures, pictures and more pictures. Work slowly and methodically and takes notes, particularly on where you disconnect color coded cables. I have changed screens on numerous brand and models and I can tell you, they have never been the same. Good luck.
Posted on Mar 06, 2009
  • Carlos Soto
    Carlos Soto Mar 07, 2009
    Anyone with mid-level experience should know enough to be careful. I know that the laptops are not only held by screws, but by little plastic latches that can break easily. Picture two interlocking "L"''s, and if you lift up incorrectly the shorter part of the "L" will break and no longer hook onto the other "L" when you put it back together. I can only stress to be careful and think forward. I normally charge $200 plus the cost of the parts and it takes me just less of an hour, less time if I have done that particular model before (because I have my notes and pictures). Good luck.
  • Carlos Soto
    Carlos Soto May 22, 2009
    Just curious, checking how things worked out with your repair?
Toshiba equim has ablack screen
Assuming the laptop IS running at least the POST tests:-
1. Try shining a torch into the screen t see if you can see any figures or characters. If so, your backlight is defective.
2. Try connecting an external monitor via the 15 pin D-type connector usually found on most laptops. If it works, get into the BIOS to check he BOOT SCREEN setting is set to LAPTOP LCD or LCD+EXT. If the LCD is dark in any case it could be the graphics chip OR the LCD is faulty.
Sep 21, 2014 | Toshiba Equium A200 Series Satellite A205...
Acer 4745g black screen problem
So, if you can hear startup sound then motherboard, RAM and HDD is OK! Try to connect it with external monitor, if it's working on it, then problem in LCD, LCD light or LCD cable. If not working with external monitor then it is video card problem, if card is integrated then you need to reball or change at all south bridge on the motherboard, if video is as module card then just replace it with compatible one.
If LCD cable - disassemble laptop to get LCD cable and test each wire with any multimetr with sound beep and replace it if needed.
If LCD light - try to take LCD screen under good lamp then power on laptop and carefully look to dark screen if you see very dark Windows boot screen then you need to disassemble LCD housing, disassemble LCD, remove and replace LCD lamp with working one.
If all this cant help, then you need to replace LCD at all.
Nov 15, 2012 | Computers & Internet
My laptop screen monitor is broken,can i replace it
Replacement LCD screens and Inverters are available from -
www.lcdparts.net
Sep 04, 2011 | HP Computers & Internet
No backlite thinkpad T43 i need free help....i am a pensioner R1000 PER month or 160 us dollars
Hi barrygarcia...
Your problem is a faulty lcd bulb, inverter board or lcd screen.
The only way to save money on your laptop repair is to do it yourself.
I could sit here and write a long procedure of how to check and replace your lcd bulb,lcd screen, or inverter board, but is is so much eaiser to view it in person.
If you are adventrous then I will send you to a youtube site to show you how to disassemble the
T-42...it disassembles like your T-43.
Please take time to rate me
T-42 disassembly
http://www.youtube.com/watch?v=YrGgXgSkiAo
If you need to replace your T-43 lcd bulb you can get one here...
http://www.yallstore.com/laptop-lcd-ccfl-backlight-lamp-for-ibm-thinkpad-t43-141-xga-p-11746.html
If you need to replace your T-43 inverter board:
http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T43/39T0361
Jul 29, 2011 | Computers & Internet
Toshiba laptop screen very dim. Icons on desktop visible at angle. model Toshiba Equium L10-300
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 13, 2011 | Computers & Internet
Hi, I have hp pavilion dv2500 laptop. I have display problem.pls help how to rectify it. If i connect exteranl CRT monitor Display is coming . Pls tell me how to disassemble the laptop.
You might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
In this service manual, you will find an illustration of how to disassemble the laptop & replace either the LCD cable or screen inverter board:
http://h10032.www1.hp.com/ctg/Manual/c01295820.pdf
Sep 17, 2010 | HP Pavilion dv2500t Notebook
How to replace a lcd screen on a sony vgn t350p
Hi. Here is a graphical instruction to disassemble your laptop and replace LCD screen. http://laptoprepair.ca/news/11776.html
and here is the service manual in case you need more info.
http://www.notebook-manuals.com/laptop-manuals/service_manual_for_SONY_VaioVGN_T350P_9e406957d4_VGN-T350P-manual-repair.pdf
Good luck.
Jun 12, 2010 | Sony VAIO VGN-T350P/T Notebook
My toshiba p300 equium accidentally drop by my niece and the lcd was broken, and im tying to use the hdmi port to my lcd t.v and still does not work, what else should i do, pls help me. tnx
replace your lcd panel from your laptop then you can turn on the external lcd tv screen
Its the only thing you can do really
Buy a secondhand unit same model and transplant the lcd panel
Apr 11, 2010 | Toshiba Satellite Pro P300 Notebook
Toshiba equium A100-306
try function key for lcd it may be in presetaiton mode by mistake
or is lcd on / come on bright then go dim / dark just very dim if so your backlight is out replace lcd
Oct 24, 2008 | Toshiba Equium 7100S PC Desktop
LCD Display
This service manual will show you how to disassemble your laptop to replace the LCD screen.
The procedure starts on page 114.
http://h10032.www1.hp.com/ctg/Manual/c00374392.pdf
Please let me know how you make out..
thanks.
Jan 29, 2008 | Computers & Internet
Computers & Internet Logo
172 people viewed this question
David Payne
David Payne
