JVC RX-9010VBK Audio/Video receiver: I sometimes get sound out of only one of two speakers. I've changed the speaker wires and even the speakers themselves, routed wires left to right but still only sound from the same one pair of wires. I've had sound from both and, when turned on again, back to only one. Any suggestions?
  • 408 Answers
You have both speakers on different channels I am assuming?
Posted on Mar 06, 2009
  • 10,594 Answers
How old is this sound system?
it seems has some lose connections or its selector switch needs cleaning.
  • 154 Answers
Check the speaker is working proper or not.
How do i connect my JVC screen tv so that i can hear out of my speakers
If your JVC TV has AUDIO OUT outputs on the rear and a provision in the initial set up screen to disable the internal speakers, you can connect to your Yamaha receiver and enjoy improved sound.
Dec 14, 2014 | Yamaha RX-V471 Receiver
My receiver only plays front speakers. when i put it in surround mode none of the speakers will play and the sub even in stereo mode is barely a whisper of sound. i dont have a remote for it but it goes...
you don't need a remote. to me sounds like you might have a connection problem. try and do a test tone which will send a test signal to all the speakers. starts from left to right etc. if you cant hear all the speakers you need to check all connection wires etc. hope this helps
Apr 08, 2014 | JVC RX-8000V Receiver
JVC RX-801V - No sound from right channel in speakers or headphones.
I'd troubleshoot first, even though you've already tried the headphones (good thinking). Get a battery (AA battery works) and put the black and red wires on opposite sides to see if the speakers are working.
Is there a menu of settings on the jvc, and is it set to 5.1? Just trying to help...
Jan 15, 2012 | JVC RX-8010V Receiver
JVC RX-8030V, I have TV Audio hooked to back of receiver (TV Audio In) but I cannot get any sound from TV to Receiver, I can hear the speakers humm when I plug the cables in but then it goes away and no...
First of all, it is bad form and potentially dangerous to be changing cables with speaker power ON. Second, IS the unidentified TV passing audio out those jacks? Its own audio menu and controls may be between the sound and the jacks.
Oct 02, 2011 | JVC RX-8030V Receiver
I have a JVC Receiver that I'm trying to hook a
"[A] set of Sony Speakers" is meaningless. What model(s)? If they're part of an all-in-one system they may not be suitable for the JVC.
Manuals exist for everything. Read them.
http://www.retrevo.com/support/JVC-RX-5052S-Receivers-manual/id/315ci175/t/2/
This receiver is designed for standard commonly available 8-ohm (nominal) speakers that connect with common stripped end lamp cord or speaker wire.
Sep 03, 2011 | JVC Audio/video Receiver Rx-5052s -...
I have a JVC RX 554v Receiver when it's turned on I have no sound their is a mute auto light that's lit in the window....Tried changing the speaker wires with no results...
From the remote control only: Press MUTING to turn off the sound through all speakers and headphones connected. "MUTE" appears on the display and the volume turns off. To restore the sound, press MUTING again. Turning MASTER VOLUME or pressing VOLUME +/- also restores the sound.
Sep 01, 2011 | JVC RX-554V Receiver
Analog only
You need to connect your source to your receiver with a Digital coax cable or a Optical cable to get true surround sound. Analog will only give you simulated surrond sound.
Mar 28, 2009 | JVC RX-5030/32 Receiver
JVC RX-9010VBK receiver - premap section won't turn on normally
It sound like a bad connection. The first thing that I would do is tighten all the ground screws that hold the circiut boards and the heat sink to the chassis. If that doen't fix it, flex the circuit boards slighty to see if the relays chick on and off (disconnect the speakers first). It could be on the input board, on the relays themselves or just about anywhere.
Feb 01, 2009 | JVC RX-9010V Receiver
Jvc receiver OVERLOAD
possible short across speaker wires somewhere or even inside speaker
Dec 21, 2007 | JVC RX-6000V Receiver
JVC receiver
Did you check impedance value and wattage on speakers you want to add to receiver?
Sep 30, 2007 | JVC RX-6018V Receiver
105 people viewed this question
 Grubhead
Grubhead
