Question about ASUS P5LD2 Motherboard
I have a P5LD2 motherboard and everything was going well, until it start to do horizontals lines on the monitor. I tried to stop the computer by the power switch, but it did not stop. I had to stop the computer at the rear. I have change the video card for a new; same problem, I have change the PCU for a new one; same problem. I have change the power supply, same problem. Everything run, but there is no signal at the monitor and no usual sound at start. What can I do next, change the motherboard, at this stage, I'll have a new computer. thanks for help
  • 139 Answers
If you are using an AGP Graphics Card, try a PCI VGA card. Maybe you have a faulty AGP adapter.
Assuming of course you know for sure that the Monitor and VGA cable are good.
Posted on Mar 06, 2009
I have horizontal lines throughout my monitor screen
Usually that is a sign the monitor is starting to fail. You can check a few things first before writing it off:
1) Check both ends of the monitor cable to make sure they are snug in the monitor and the back of the computer.
2) Try replacing the monitor cable with a new one, or a known working one.
3) Try the monitor on another computer.
If none of those improve your situation it may be time for a new monitor (but check if yours still has warranty)
Jan 11, 2011 | Computers & Internet
P5ld2-vm/s mother board lan drivers
i have a LAN Driver of model no. p5ld2-vm/s is the branded computer of HCL, that motherboard name is ASUS
Mar 23, 2010 | ASUS P5LD2-VM Motherboard
At start up my monitor will show black horizontal (even vertical sometimes) lines. If I turn off the monitor it does not help, if I turn off the computer it does not help, if I disconnect my modem and then...
i think virus attack in your hard disk or remove ram and start the computer after some time shut down comuter and again attach ram in memory slot if your problem not solve then check your motherboard
Nov 19, 2009 | Compaq Computers & Internet
A verticle yellow line/ horizontal white line on my vaio? Lines are thin
LCD needs to be replaced. if you are very tech savvy you can reseat the lcd cable. but 99% of times it doesnot do anything. its the lcd that needs to be replaced. to see how to reseat the lcd cable. select your computer model on sony vaio website and then go to drivers and downlaods and then go to user manuals and then select adding or repalcing the parts and then you can find the way to do it. i suggest get the lcd repalced.
before you do try this 1 step.
connect an external monitor, and start the computer and then press fn + F8 or try to extend the view to external monitor, if the image is okay, then its the lcd if you see the lines on the external monitor (which is 1% of 100 %) then its the motherboard.
all the best.
Oct 13, 2009 | Sony Computers & Internet
My cpu dont see new hdd wd5000avvs ,motherboard Asus P5LD2 SE. i trying omost everything. help;/
are you using ide or sata connection? if your using sata conection between your motherboard and harddrive, you must enable it in your bios, just reboot your pc and keep pressing F2 while its booting to prompt your bios. There you can look for IDE/SATA configuration. After enabling your sata, save any changes before you exit and reboot... Just give it a try...
Jun 22, 2009 | ASUS P5LD2-VM Motherboard
Mugen MC1524D horizontal line shake on upside
Find the button that says DEGAUSS push it...
next try to increase your refresh rate of the monitor which is controlled by the video software in you computer...right click in a blank area go to properties at the bottom click-> on that hit the Settings tab look for ->advanced box towards the bottom right->click on the Monitor tab -> in the middle it will say "Screen refresh rate" use the drop down arrow and select at least 70-75 Hertz.
this just may stop it from jumping about...good luck and hope this help...
Apr 23, 2009 | SAMTRON 55V 15" CRT Monitor
Horizontal lines
Horizontal blur can be caused by both a bad monitor or a bad video card/Card Slot on the motherboard.
The easiest way to check this is to connect the monitor to a known good system. If the problem follows the monitor to the good system, the monitor is bad and will need replacement. If it works fine on another system the problem is the video card/slot
Jan 04, 2008 | Dell E207WFP LCD Monitor
Incorrect power management
Dear u have a problem with VGA or Monitor...U should try to put new vga in you'r mother board and try.If still wont work then you have a problem with monitor
Oct 11, 2007 | ASUS P5LD2-VM Motherboard
ASUS P5LD2 Motherboard Logo
197 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
